how to mapcar rtos 2 2
devitg
Advisor Advisor
Message 1 of 14
devitg
For this list
(210.655 98.7758)
How to apply mapcar to rtos 2 2
to get
("210.65" "98.77")
Replies (13)
Message 2 of 14
cadffm
Use something like a loop,
iterate thru the list and do what you want..
FOREACH WHILE REPEAT... or
 a mapcar with a fancy anonymous lambda ...
(setq MyList '(210.655 98.7758))
(mapcar '(lambda(n)(rtos n 2 2 ))MyList)
Sebastian
Message 3 of 14
Shneuph
This works.. but I guess you can't pass the options to the rtos function
(setq l1 '(210.655 98.7758))
(Setq l2 (mapcar 'rtos l1))
That's why you had to make a lambda function?
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 4 of 14
devitg
That it is.
Also it will give the chance to at last understand LAMBDA .
Since I see it , I never understand LAMBDA .
Hope it will be, LAMBDA, clear to me.
Message 5 of 14
cadffm
hmm - I guess i have a translation problem, SORRY:
I don't know what you asked about, devitg didn't ask about options and passing!?
MAPCAR  expected ONE function and one or more lists,
so i defined a function like i need.
If you want a function for using more often, define a named function and add it to your library.
(defun rtos+ (LI MODE PREC) ; never forget dimzin unitmode luprec
  (if (= 'LIST (type LI))
       (mapcar '(lambda (N) (rtos N (if MODE MODE (getvar 'DIMLUNIT)) (if PREC PREC (getvar 'LUPREC))) LI)
Sebastian
Message 6 of 14
cadffm
lambda - on the surface
is like defun, but without a name, so you can use it only at one place.
(if you would create a named function by defun, it is easy to use this function at multiple locations in your code)
So:
If you are sure that you need a function only at one place in your code, you can use lambda to save memory and free symbolnames.
If you knowing you can use a function multiple times in the code, or this function is an extra logical part of your program, use defun.
Sebastian
Message 7 of 14
Shneuph
I was just saying that, this works:
but returns this (for me): ("17'-6 21/32\"" "8'-2 199/256\"")
...and there is no way to pass rtos to mapcar withe the options the op wanted. the 2's:
(Setq l2 (mapcar 'rtos 2 2 l1))<-- Does not work.
Message 8 of 14
hak_vz
Hi @devitg
My post is maybe a bit out of topic regarding using mapcar and rtos, but you may
find this useful.
Here is a function that converts real number to conform to ISO number representation,
i.e. number is formatted to # ### ###,###  or   # ### ###.### pattern.
(defun format_number (num decimals  delimiter / por b i ret neg)
    (if (minusp num) (setq neg "-") (setq neg ""))
    (setq rest(- (abs num) (fix (abs num))))
    (if (and (> rest 0.5) (= decimals 0)) (setq num (+ num 1)))
    (setq rest (substr (rtos rest 2 decimals) 3) ret "")
    (setq poz (vl-string-position (ascii ".") rest))
    (setq num (abs (fix num)) i 0 j 0)
    (while (> num 0.0)
        (setq por (cons (fix (rem num 1000.0)) por)
              num (/ (- num (car por)) 1000.0)
    (while (< i (length por))
        (setq b (rtos (nth i por) 2 0))
        (if (and (eq (strlen b)1) (> i 0)) (setq b (strcat "00" b)))
        (if (and (eq (strlen b)2) (> i 0)) (setq b (strcat "0" b)))
        (if (< i (- (length por) 1)) (setq ret (strcat ret b " ")) (setq ret (strcat ret b)))
        (setq i (+ 1  i))
    (if (= (strlen ret) 0) (setq ret "0"))
    (if (= decimals 0) (setq delimiter "" rest ""))
    (strcat neg ret delimiter rest)
(defun format_list_of_numbers (lst decimals delimiter)
    (mapcar '(lambda (x) (format_number x decimals delimiter)) lst))
Here is a usage sample:
(format_list_of_numbers '(1050250.353 -25254.343545 35.35356) 3 ",")
>>("1 050 250,353" "-25 254,344" "35,354")
Miljenko Hatlak
Message 9 of 14
dlanorh
You can also pass a lambda function
(defun myfunct (lst fun)  (mapcar fun lst))
Command: (myfunct (list (list 1 "A") (list 2 "B") (list 3 "C")) '(lambda (x) (cadr x))) => ( "A" "B" "C")
I am not one of the robots you're looking for
Message 10 of 14
cadffm
Right, because of...how mapcar is defined and works.
Sure not, Press [F1] and read about the MAPCAR Lispfunction instead of wild testings.
Mapcar want one function (first argument) and one (or more) lists.
(mapcar 'DoThis withthisList1)
http://help.autodesk.com/view/ACD/2020/DEU/?guid=GUID-8802AE73-1A05-457E-8A51-09677C23E26E
No place for passing arguments to the function, so i need a function which includes my rtos arguments... my lambda function!
Sebastian
Message 11 of 14
john.uhden
I get it, but it seems to me that if MODE and PREC are both nil, then just
(mapcar 'rtos LI)
John F. Uhden
Message 12 of 14
cadffm
Sure, but this was not the question.
Sebastian
Message 13 of 14
john.uhden
Understood.  I was just chiming in with a note of interest since I am bored at home basically doing nothing.
My wife wishes that we had a big yacht to disappear out into the ocean to avoid this mess.
John F. Uhden
Message 14 of 14
cadffm
You made my day 🤣
Sebastian
