modify MMP.lisp to insert ATTRIBUTE, TEXT, MTEXT, RTEXT, DTEXT.
jtm2020hyo
Message 1 of 8
jtm2020hyo
A time ago I found a beautiful lisp (attached), but I need a hero to modify this lisp to insert ATTRIBUTE, TEXT, MTEXT, RTEXT, DTEXT with the same method.
;|  MarkMidPoints.lsp [command name: MMP]
To MARK the MIDPOINT(S) of selected object(s), with Points, Blocks, or Lines.
Points option:  sets PDMODE and PDSIZE to make Points visible.
Blocks option:  any Block in drawing or drawing in Support File path list, any
  scale, any rotation including Aligned-with-object and Relative-to-object options.
Lines option:  perpendicular at midpoint(s); User specifies length of Lines.
For Polylines, option to mark midpoints of all segments, or only overall midpoint.
Kent Cooper, last edited 8 May 2018 [multiple-object selection]
(vl-load-com)
(defun C:MMP ; = Mark Mid-Points
  (/ *error* mmp-dir svnames svvals blktemp scltemp rotdef rottemp laydef
  laytemp pathsel doc path pathdata pathtype pathextr ucschanged par mmp-pt)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg))
    ); if
    (if ucschanged (command-s "_.ucs" "_prev"));; [remove  -s  for pre-2015 version]
      ;; ^ don't go back unless routine reached UCS change but didn't change it back
    (vla-endundomark doc)
    (mapcar 'setvar svnames svvals); reset
    (princ)
  ); defun - *error*
  (defun mmp-dir () ; local DIRection [radians] of path at mmp-pt location
    (angle
      '(0 0 0)
      (trans
        (vlax-curve-getFirstDeriv
          path
          (vlax-curve-getParamAtPoint path (trans mmp-pt 1 0))
        ); getFirstDeriv
        0 1 T ; world to current CS, as displacement
      ); trans
    ); angle
  ); defun - mmp-dir
  (prompt "\nTo Mark Mid-Points,")
  (if (setq ss (ssget '((0 . "LINE,ARC,CIRCLE,ELLIPSE,*POLYLINE,SPLINE"))))
    (progn ; then
      (setq
        svnames '(osmode blipmode ucsfollow cmdecho clayer)
;;; pdmode/pdsize saving possibility -- not included so Points
;;; remain visible after use; add to svnames list if desired
        svvals (mapcar 'getvar svnames)
      ); setq
      (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
      (setvar 'cmdecho 0)
      (initget "Blocks Points Lines")
      (setq _mmp-type_
        (cond
          ( ; User entry
            (getkword
              (strcat
                "\nMark with Points/Blocks/Lines? <"
                (substr (cond (_mmp-type_) ("Points")) 1 1)
              ); strcat
            ); getkword
          ); User entry condition
          (_mmp-type_); existing default if present on Enter
          ("Points"); default on first use
        ); cond
      ); setq
      (cond
        ((= _mmp-type_ "Blocks")
          (while
            (cond
              ((not blktemp)); none yet [first time through (while) loop]
              ((and (= blktemp "") (= (getvar 'insname) "")))
                ; User hit Enter, but no MMP or Insert defaults
              ((and
                  (/= blktemp ""); User typed something, but
                  (not (tblsearch "block" blktemp)); no such Block in drawing
                  (not (findfile (strcat blktemp ".dwg"))); no such drawing in Search paths
                ); and
              ); condition
            ); cond
            (setq blktemp
              (getstring
                (strcat
                  "\nBlock to insert to Mark Mid-Point(s) on path(s)"
                  (cond
                    (_mmp-blk_ (strcat " <" _mmp-blk_ ">")); prior Block used, if any
                    ((/= (getvar 'insname) "") (strcat " <" (getvar 'insname) ">")); offer Insert's default, if any
                    (T ""); no default offered on first use if no MMP or Insert defaults
                  ); cond
                ); strcat
              ); getstring and blktemp
            ); setq
          ); while
          (setq _mmp-blk_
            (cond
              ((/= blktemp "") blktemp); User typed something
              (_mmp-blk_); default, if any
              ((getvar 'insname)); Enter on first use with Insert default
            ); cond
          ); set
          (initget 134 "Graphic")
          (setq scltemp
            (getkword ; [returns nil on Enter]
              (strcat
                "\nScale for Blocks, or Graphic for symbol scaled to drawing <"
                (cond
                  ((= _mmp-scl_ (getvar 'dimscale)) (strcat (rtos _mmp-scl_ 2 4) "= Graphic scale"))
                  (_mmp-scl_ (rtos _mmp-scl_ 2 4))
                  (T "1"); default on first use
                ); cond
              ); strcat
            ); getkword and scltemp
          ); setq
          (setq _mmp-scl_
            (cond
              ((= scltemp "Graphic") (getvar 'dimscale)); User chose Graphic; get drawing scale
              ((and scltemp (/= (atof scltemp) 0)) (atof scltemp)); User typed numerical string; convert to number
              (T (cond (_mmp-scl_) (T 1))); User hit Enter and there's a default, then - use it; else - 1 [first use]
            ); cond and scale
          ); set
          (initget 32 "Aligned Relative"); dashed rubber-band if picked on-screen
          (setq
            rotdef (cond (_mmp-rot_) (T "Aligned")); Aligned default on first use
            rottemp
              (getangle
                (strcat
                  "\nBlock rotation, or Aligned with path or Relative angle to path [angle/A/R] <"
                  (if (numberp rotdef); if default is a number,
                    (angtos rotdef); then - text, current angle units
                    (substr rotdef 1 1) ; else - "A" or "R"
                  ); if
                ); strcat
              ); getangle and rottemp
          ); setq
          (setq _mmp-rot_
            (cond
              ((numberp rottemp) rottemp)
                ; User typed number
              (rottemp); User typed A or R
              (rotdef); otherwise, User hit Enter -- use default
            ); cond and rot variable
          ); set
          (if (= _mmp-rot_ "Relative")
            (progn
              (initget 36)
                ; no negative, dashed rubber-band if picked on-screen
              (setq _mmp-rel_
                (cond
                  ( ; User input
                    (getangle
                      (strcat
                        "\nAngle of Blocks Relative to path direction <"
                        (if _mmp-rel_ (angtos _mmp-rel_) "0"); designate units/precision if desired
                      ); strcat
                    ); getangle & reltemp
                  ); User input condition
                  (_mmp-rel_); existing default if present
                  (0); 0 default on first use
                ); cond
              ); setq
            ); progn
          ); if
        ); Blocks condition
        ((= _mmp-type_ "Lines")
          (if _mmp-lin_
            (initget 6); then - no zero, no negative
            (initget 7); else - no zero, no negative, no Enter on first use
          ); end if
          (setq _mmp-lin_
            (cond
              ( ; User input
                (getdist ; [returns nil on Enter]
                  (strcat
                    "\nEnter length of marking Lines"
                    (if _mmp-lin_ (strcat " <" (rtos _mmp-lin_) ">") ""); default if present
                  ); end strcat
                ); end getdist and lintemp
              (_mmp-lin_); default
            ); cond
          ); end setq
        ); Lines condition
        (T (setvar 'pdmode 35) (setvar 'pdsize -3)); Points - change values as desired
      ); cond - Blocks or Lines or Points
      (setq laydef (cond (_mmp-lay_) ("Current"))); current-Layer first-use default
      (initget 128 "Current Same"); allow Enter or non-keyword input
      (while
        (and
          (setq laytemp
            (getkword ; User input other than Enter,
              (strcat
                "\nLayer for "
                _mmp-type_
                ", or Current, or Same as selected path <"
                laydef
              ); strcat
            ); getkword and laytemp
          ); setq
          (not (wcmatch laytemp "Current,Same")); and it wasn't C or S,
          (not (tblsearch "layer" laytemp)); and Layer is not in the drawing
        ); and
        (prompt "\nLayer does not exist in this drawing--")
          ;;;; [add option to Make it?]
      ); while
      (setq _mmp-lay_ (cond (laytemp) (T laydef)))
        ; User input [including C or S], then - use it; else - default
      (if (not (wcmatch _mmp-lay_ "Current,Same"))
        ; if it's a Layer name that does exist, not current nor the object's,
        (command "_.layer" "_thaw" _mmp-lay_ ""); then - ensure it's Thawed; set current later
      ); if
      (initget "All Overall")
      (setq _mmp-plseg_
        (cond
          ( ; User entry
            (getkword
              (strcat
                "\nOn Polyline, mark All segments or Overall midpoint [A/O]? <"
                (substr (cond (_mmp-plseg_) ("All")) 1 1)
              ); strcat
            ); getkword
          (_mmp-plseg_); existing default if present on Enter
          ("All"); default on first use
        ); cond
      ); setq
      (mapcar 'setvar svnames '(0 0 0)); osnap, blips, ucsfollow off
      (repeat (setq n (sslength ss)); then
        (setq
          path (ssname ss (setq n (1- n)))
          pathdata (entget path)
          pathtype (cdr (assoc 0 pathdata))
          pathtype
            (if (wcmatch pathtype "POLYLINE")
              (strcase (substr (cdr (assoc 100 (cdr (member (assoc 100 pathdata) pathdata)))) 5)); then
                ;; ^ = entity type from second (assoc 100) without "AcDb" prefix;  uses this because (assoc 0)
                ;; value is the same for 2D heavy & 3D Polylines; can set UCS to match former, but not latter
              pathtype ; else - leave alone
            ); if and pathtype
          pathextr (cdr (assoc 210 pathdata))
        ); setq
        (if ; set UCS to match object only under certain circumstances
          (or ; look at entity types other than 3D Polylines and 3D Splines
            (and
              (= pathtype "LINE")
              (not ; unequal Z components at ends, in current CS
                (equal
                  (caddr (trans (cdr (assoc 10 pathdata)) 0 1))
                  (caddr (trans (cdr (assoc 11 pathdata)) 0 1))
                  1e-12
                ); equal
              ); not
            ); and - Line UCS check
            (and
              (wcmatch pathtype "ARC,CIRCLE,ELLIPSE,LWPOLYLINE,2DPOLYLINE"); omit Circle if desired
              (not (equal (trans pathextr 0 1) '(0 0 1) 1e-12)); extrusion direction not = current CS
            ); and - A/C/E/LWP/2dP UCS check
            (and
              (= pathtype "SPLINE")
              (if pathextr (not (equal (trans pathextr 0 1) '(0 0 1) 1e-12)))
                ;; ^ planar [2D] Splines have 210 value; non-planar [3D] do not
            ); and - Spline UCS check
          ); or - need to change UCS
          (progn
            (if (equal pathextr '(0 0 1) 1e-12)
              (command "_.ucs" "_world")
              (command "_.ucs" "_new" "_object" path); set UCS to match object
            ); if
            (setq ucschanged T) ; marker for *error* to reset UCS if routine doesn't get to it
          ); progn
        ); if - UCS match object
        (if (/= _mmp-lay_ "Current"); set Layer only if Current not selected
          (command "_.layer" "_set" ; [this instead of (setvar 'clayer) will turn it on if it's off]
            (if (= _mmp-lay_ "Same")
              (cdr (assoc 8 pathdata)); then - get layer of object
              _mmp-lay_ ; else - use specified Layer
            ); if
          ); command - Layer
        ); if - not Current Layer
        (setq par -0.5)
        (repeat
          (if (and (wcmatch pathtype "*POLYLINE") (= _mmp-plseg_ "All"))
            (fix (vlax-curve-getEndParam path)); then
            1 ; else - other object types
          ); if
          (setq mmp-pt
            (trans
                (vlax-curve-getPointAtParam path (setq par (1+ par))); then
                (vlax-curve-getPointAtDist ; else - midway along length
                  path
                    (vlax-curve-getDistAtParam path (vlax-curve-getEndParam path)); overall length
                    2
                ); getPointAtDist
              ); if
              0 1
            ); trans and mmp-pt
          ); setq
          (cond
            ((= _mmp-type_ "Points") (command "_.point" mmp-pt))
              (command
                "_.insert" _mmp-blk_
                "_scale" _mmp-scl_
                mmp-pt ; insertion point
                (cond ; rotation
                  ((= _mmp-rot_ "Aligned") (angtos (mmp-dir))); local direction
                  ((= _mmp-rot_ "Relative") (angtos (+ (mmp-dir) _mmp-rel_))); local direction + relative angle
                  ((angtos _mmp-rot_)) ; otherwise - specified constant angle
                ); cond - rotation
              ); command
            ); Blocks condition
            (T ; [Lines]
              (command
                "_.line"
                (polar
                  mmp-pt
                  (+ (mmp-dir) (/ pi 2))
                  (/ _mmp-lin_ 2)
                ); polar
                (polar
                  mmp-pt
                  (- (mmp-dir) (/ pi 2))
                  (/ _mmp-lin_ 2)
                ); polar
              ); command
            ); none-of-the-above [Lines] condition
          ); cond
        ); repeat
        (if ucschanged (command "_.ucs" "_prev"))
        (setq ucschanged nil); eliminate UCS reset in *error* since routine did it already
      ); repeat
    ); progn
  ); if
  (princ)
); defun - MMP
(prompt "Type MMP to Mark the Mid-Points of selected object(s).")
Replies (7)
Message 2 of 8
devitg
Do you mean insert such ATTRIBUTE, TEXT, MTEXT, RTEXT, DTEXT. at midpoints??
Please upload sample.dwg to apply it
Message 3 of 8
ВeekeeCZ
Jesus!! @jtm2020hyo  this is sooo disrespectful from you! Seriously! I know that you know the *** about programming but can you at least read? Or are you blind? Or are you so disrespectful because your mum raised you so bad?
The routine you found has its author! His name is listed in the perex! So please, do yourself a favor and read it. You are begging here for help for time long enough to know, that the author is a regular member here.
It looks like you will never be able to write anything, not to mention the routine like this one, so at least be respectful, grateful and credit ones who deserve it!
So, thank you @Kent1Cooper for this awesome routine that you wrote!!
Sorry for being disrespectful to you, @jtm2020hyo  but it could be much worse!
Message 4 of 8
jtm2020hyo
I request something like this:
http://www.lee-mac.com/midlen.html
basically I need to insert any *text in the middle of any *line, but with fields. something like "length field" and "layer field".
Message 5 of 8
devitg
I'm sad to say ACAD can not handle a png , but can handle a DWG,
Furthermore , do the text to be some entity property?
Message 6 of 8
jtm2020hyo
sorry, I was thinking this is not needed.
in my attached drawing explain better what I need.
PD: the lisp MMP has the properties additional that I need, such as rotation, align, etc, that is why I attached as a reference of how should work the lisp
PD: below an image, basically I just need to insert mtext with any field.
Message 7 of 8
jtm2020hyo
I think is a good idea to update the lisp. until now it was not done in any forum...
about me, I found another alternative. but there I leave the idea.
Message 8 of 8
Kent1Cooper
@jtm2020hyo wrote:
.... I need to insert any *text in the middle of any *line, but with fields. something like "length field" and "layer field".
For the length [only], I have a routine LengthAtMidpoint.lsp with its LMP command, available >here<, that puts Text of the length of any appropriate object at its midpoint.  It's not a field, and it's comparatively basic, and it puts the Text above rather than centered on the "path," but it already exists.
Some day I will put some time into working Text capability into MMP, but not right now....
Kent Cooper, AIA
