Code debugging
Code debugging
support201
Message 1 of 17
Code debugging
support201
Dear all,
My customer is using add-on AutoLISP for AutoCAD. He made a code of AutoLISP inorder to export the table of Point Coordinates, but the output value after exporting is incorrect. For detail, the problem is that when he run Autolisp, the X coordinates of the output points were negative coordinates instead of positive as they should be . Additionally, the coỏrdinate origin moved to another position. Kindly see the attachment for more details
Please help me to fix the code of AutoLISP
Thanks so much
Duc Tran
Replies (16)
Message 2 of 17
ВeekeeCZ
Do I understand you correctly that you are providing some purchased services and the actual work you're using from us?
Message 3 of 17
support201
My customer. Yes, my customer has purchased AutoCAD, and he use AutoLISP for AutoCAD, and now he need your help to debug his code of AutoLISP
Message 4 of 17
devitg
Why not use DATAEXTRACTION .
Please show the dwg before the lisp was  applied
Message 5 of 17
support201
Hello Devitd,
I would like to provide the drawing before running LISP, pls see the attachment
When I use Dataextraction, there is a problem that when I export the table of coordinates inorder to manufacture there is no coordinate in the table
Message 6 of 17
devitg
Find attached both the dwg  with  table and Xls , also the CIRCLE DATA.dxe to be used when Data extraction dialog box ask
Message 7 of 17
devitg
attached
Message 8 of 17
support201
Hello Devitg,
Thank you so much for your help. But I am afraid that the result is not correct. There are 2 points which their X coordinates should be 0. Kindly see the attachment
Message 9 of 17
devitg
It seem to be the fact is your UCS. set it to World
checking
Message 10 of 17
devitg
I did check it , if I set UCS to world , and move all circles from the left-down-most, to 000 , and a set a new dxe , it work as expected . find attached
Message 11 of 17
devitg
attached
Message 12 of 17
support201
Hello Devitg. thank you so much. the result is correct. But I need to debug my code in AutoLISP. Because I want to use AutoLISP to do not only exporting coordinates but also the other things. So could you please help me to find the issue in my code?
Message 13 of 17
cadffm
There is no issue, but alle data are stored in the one and only WCS.
If you read the object data -> WCS!
UCS are for the User only, as help for a better workflow with less calculatings for the user (but more for the program).
If you like to know what the coordinate are in UCS system, Press Help [F1] and read about TRANS (LispFunction)
(trans (cdr(assoc 10 (setq el (entget(setq en (car(entsel))))))) en 1)
Sebastian
Message 14 of 17
support201
Thanks so much. I tried to change the code from 0 to 1 but it failed. What should I do? Kindly see the attachments
Message 15 of 17
cadffm
I don't understand what your post have to do with my answer!?
You new Table looks good except you changed "my setting" from OCS to ??? perhaps to WCS,
i don't know - you didn't post the used new code here.
The problem is: "We" know how Acad works, also Lispfunctions, but we don't know about your AutoCAD and Lisp knowledge,
so it is difficult to answer in the best way for you.
Sorry, i am out.
It take too many time to teach all stuff from scratch (WorldCoordinateSystem WCS, User(defined)CoordinateSystem UCS, and for programming - Object coordinate system OCS / DXF 210)
If your wanted coordinate system is active, like in your sample file,
 you can use me TRANS setting to convert Circle-Center coordinates from OCS to UCS data.
I don't test your code, because you uses commands and didn't internationalized it,
Text prompt are not in english, so it is hard to follow the steps for a successfull input.
(I start CTC, what i have to type in to get the same result like you? CTC,16,2,A1,E(?),PickPoint(?),a Number(?),ObjectSelection(?), H(?) -> not working for example)
Try this to set the PNTS variable:
(setq pnts (append pnts (list (trans (cdr (assoc 10 (entget (ssname rfob n)))) (ssname rfob n) 1))))
Sebastian
Message 16 of 17
devitg
Please clear what other thing , and try to translate from VN to EN  quoted text at  the LSP file
Message 17 of 17
support201
I attached the code in English, pls see the attachments
