Modify layer description in lisp
I've got a layer setup in a lisp that I want to assign different Layer Description into each on of them. Which part is controlling layer description in a lisp? Here is part of my lisp:
(entmakex (list '(0 . "LAYER")
			  (cons 100 "AcDbSymbolTableRecord")
			  (cons 100 "AcDbLayerTableRecord")
			  (cons 2 "PIPE_S")
			  (cons 70 0)
			  (cons 62 6)
			  (cons 6 "Center")
			  (cons 370 25)))))
regisrohde
I think this can help you:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/create-new-layers-lisp/td-p/3560508
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
ВeekeeCZ
I'll make it easier for you...
Spoiler
(vl-load-com)
(defun c:XX (/ ss i sset oEXPERT cmde tmod llst la lnam lfrz loff)
  (setq oEXPERT (getvar 'EXPERT))
  (prompt "\n Select object to put on layer [PIPE_S].. ") ;unify the layer name, is it PIPE_S or PIP_S?
  (if (setq ss (ssget "_:L"))
    (repeat (setq i (sslength ss))
      (setq sset (ssname ss (setq i (1- i))))
      (if (not (tblsearch "LAYER" "PIPE_S"))
	(progn
	  (setvar 'EXPERT 3)
	  (command "_.-LINETYPE" "_LOAD" "Center" "acad.lin" "") ;change *.lin if different
			  (cons 2 "PIPE_S")
			  (cons 70 0)
			  (cons 62 6)
			  (cons 6 "Center")
			  (cons 370 25)))
	  (vla-put-description (vlax-ename->vla-object (tblobjname "LAYER" "PIPE_S")) "Your description")
      (entmod (subst (cons 8 "PIPE_S")
		     (assoc 8 (entget sset))
		     (entget sset))))
    (princ "\n Nothing selected "))
  (setq cmde (getvar "cmdecho") ;here was an extra left bracket
	tmod (getvar "tilemode")
	llst ""
	la (tblnext "layer" T))
  (setvar "cmdecho" 0)
  (while la
    (setq lnam (cdr (assoc 2 la))
	  lfrz (= (logand (cdr (assoc 70 la)) 1) 1)
	  loff (minusp (cdr (assoc 62 la))))
    (if (or lfrz loff)
      (progn
	(if (setq ss (ssget "x" (list (cons 8 lnam))))
	  (command "_.-layer" "_u" lnam ""
		   "_.erase" ss ""))
	(setq llst (strcat lnam "," llst)
	      la (entget (tblobjname "layer" lnam))
	      la (subst '(70 . 0)(assoc 70 la) la))
	(entmod la)))
    (setq la (tblnext "layer")))
  (if (> llst "")
    (command "_.tilemode" 0
	     "_.vplayer" "_t" llst "_a" ""))
  (repeat 3
    (command "_.purge" "_a" "*" "_n"))
  (setvar 'EXPERT oEXPERT)
  (setvar "cmdecho" cmde)
  (setvar "tilemode" tmod)
  (princ)
pbejse
@Anonymous wrote:
... Which part is controlling layer description in a lisp? Here is part of my lisp:
Try this..
(progn
  (regapp "AcAecLayerStandard")
  (entmake
    (append
	    (cons 2 "PIPE_S")
	    (cons 70 0)
	    (cons 62 6)
	    (cons 6 "Center")		;<< make sure linetype is loaded
	    (cons 370 25)
      (list
	(list -3
	        (list "AcAecLayerStandard"
	            (cons 1000 "")
	            (cons 1000 "Description Here")
HTH
and if I want to add a Warning messge to this routine's body??
(vl-load-com)
	(progn
	  (setvar 'EXPERT 3)
			  (cons 2 "PIPE_S")
			  (cons 70 0)
			  (cons 62 6)
			  (cons 6 "Center")
			  (cons 370 25)))
		     (entget sset))))
	llst ""
  (while la
    (if (or lfrz loff)
      (progn
		   "_.erase" ss ""))
	(entmod la)))
  (if (> llst "")
  (repeat 3
  (princ)
ВeekeeCZ
Ok, I added Henrique's suggestion into your routine. Also I rearranged that a little bit...
Spoiler
(vl-load-com)
(defun c:XX ( /  *error* ss i sset oCMDECHO oTILEMODE oEXPERT llst la lnam lfrz loff)
  (defun *error* (errmsg)
    (if	(not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
    (setvar 'CLAYER oCLAYER)
    (setvar 'TILEMODE oTILEMODE)
    (setvar 'CMDECHO oCMDECHO)
    (vla-endundomark doc)
    (princ)
  (setq oCMDECHO (getvar 'CMDECHO))
  (setq oTILEMODE (getvar 'TILEMODE))
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (setvar 'CMDECHO 0)
	(progn
	  (setvar 'EXPERT 3)
			  (cons 2 "PIPE_S")
			  (cons 70 0)
			  (cons 62 6)
			  (cons 6 "Center")
			  (cons 370 25)
		     (entget sset)
  (if (= (ACET-UI-MESSAGE
	   "Do you want ERASE ALL objects on FROZEN and TURNED OFF layers?"
	   "Erase objects?"
	   (+ Acet:YESNO Acet:ICONWARNING)
	 6
    (progn
      (setq llst ""
      (while la
	(if (or lfrz loff)
	  (progn
	      (command "_.-layer" "_u" lnam "" "_.erase" ss "")
		  la   (subst '(70 . 0)
			      (assoc 70 la)
			      la)
	    (entmod la)
      (if (> llst "")
	(command "_.tilemode" 0	"_.vplayer" "_t" llst "_a" "")
  (repeat 3 (command "_.purge" "_a" "*" "_n"))
  (princ)
