Warning message before applying a function
I have a simple lisp which I want to have a warning dialogue window (Yes to accept /No to exit) to prevent any accidentally running this lisp.
(defun c:deltext ( / ss )
(setq ss (ssget "x" (list (cons 0 "text"))))
(if ss
(command ".erase" ss "")
(princ "\nNo text in this drawing!")
(princ)
hmsilva
Something like this, perhaps
(defun c:deltext (/ ss)
  (if (and (setq ss (ssget "x" (list (cons 0 "text"))))
           (= (ACET-UI-MESSAGE
                "Do you want to delete all texts?"
                "You are about to delete all texts!!!"
                (+ Acet:YESNO Acet:ICONQuestion)
              6
  (princ)
Hope this helps,
Henrique
pbejse
  (princ)
Hope this helps,
Henrique
Me like it 🙂
hmsilva
@pbejse wrote:
Me like it 🙂
Hi pBe, nice hearing from you! Smiley Happy
Henrique
Thank you all
and if I want to add this  warning message to attached lisp, what will be the code?
(defun c:UnDynamic
        _get_item
        _right
        _make_key
        _dynamic->static_block
        _get_locked
        _get_dynamic_inserts
        _main
    (defun _get_item ( collection key / item )
        (vl-catch-all-apply
           '(lambda ( ) (setq item (vla-item collection key)))
        item
    (defun _right ( str n / len )
        (if (< n (setq len (strlen str)))
            (substr str (1+ (- len n)))
            str
    (defun _make_key ( collection prefix len / key )
        (   (lambda ( i pad )
                (while
                    (_get_item collection
                        (setq key
                            (strcat prefix
                                (_right
                                    (strcat pad (itoa (setq i (1+ i))))
                                    len
                key
            0
            (   (lambda ( pad )
                    (while (< (strlen pad) len)
                        (setq pad (strcat "0" pad))
                    pad
    (defun _dynamic->static_block ( blocks insert len )
        (vla-ConvertToStaticBlock
            insert
            (_make_key blocks "STATIC_" len)
    (defun _get_locked ( layers / locked )
        (vlax-for layer layers
            (if (eq :vlax-true (vla-get-lock layer))
                (setq locked (cons layer locked))
        locked
    (defun _get_dynamic_inserts ( blocks / inserts )
        (vlax-for block blocks
            (vlax-for object block
                (if (eq "AcDbBlockReference" (vla-get-objectname object))
                    (if (eq :vlax-true (vla-get-isdynamicblock object))
                        (setq inserts (cons object inserts))
        inserts
    (defun _main ( document / blocks inserts locked len )
        (if
            (setq inserts
                (_get_dynamic_inserts
                    (setq blocks (vla-get-blocks document))
            (progn
                (foreach layer (setq locked (_get_locked (vla-get-layers document)))
                    (vla-put-lock layer :vlax-false)
                (setq len (strlen (itoa (length inserts))))
                (foreach insert inserts
                    (_dynamic->static_block blocks insert len)
                (foreach layer locked
                    (vla-put-lock layer :vlax-true)
        (princ)
    (_main (vla-get-activedocument (vlax-get-acad-object)))
hmsilva
Change
to
(if (= (ACET-UI-MESSAGE
           "Do you want to convert to static all dynamic blocks?"
           "You are about to convert to static all dynamic blocks!!!"
           (+ Acet:YESNO Acet:ICONWARNING)
         6
Hope this helps,
Henrique
