MLeader text position and justification
SAPER59
SAPER59
I need to change the text position from one side to the other from  mleader arrow extreme and so must change text point and text justification
I tried with (vla-put-TextJustify   (vla-put-TextRightAttachmentType  (vla-put-TextDirection  but can not get it
I can rotate it with vla-put-TextRotation to align with the line I want to,  but need to put the text from the side the "flow direction" comes
Thanks in advance to any sugestion
ВeekeeCZ
Post a dwg example with states before and after to take a look.
SAPER59
Here is the file
When goes from one side do it ok and changing the direction, no
Thanks for your time
CodeDing
@SAPER59,
Even with your drawing it is hard to understand what you are asking for. Can you explain more? Have you tried using the MIRROR command?
Best,
~DD
SAPER59
I create the mleader with (vla-AddMLeader ....... so I can not mirror it, and I don't use (command line ...)
I need to represented the "flow" from one end to the other end of the line)
When the flow goes in inverse direction the mleader is created as mirrored respect the other
The point is that I can not positioned the text and small line in the right way
If you have a look in parallel lines is represented both directions one for line, and in one the mleader is OK and in the other no.
Thanks anyway
CodeDing
@SAPER59,
I am sorry if I still do not fully understand. But it looks like you should be looking into either MIRRTEXT or the vla-Mirror method. I wish I could provide more help for you. Here is some code I was experimenting with.
(vl-load-com)
(defun c:TESTLEADER()
    (setq acadObj (vlax-get-acad-object))
    (setq doc (vla-get-ActiveDocument acadObj))
    ;; Define the leader points
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
    (vlax-safearray-fill points '(1 1 0
                                  10 10 0
    ;; Add the mleader object to model space
    (setq modelSpace (vla-get-ModelSpace doc))
    (setq mLeader (vla-AddMLeader modelSpace points i))
    (setq mp1 (vlax-make-safearray vlax-vbDouble '(0 . 2)))
    (vlax-safearray-fill mp1 '(0 0 0))
    (setq mp2 (vlax-make-safearray vlax-vbDouble '(0 . 2)))
    (vlax-safearray-fill mp2 '(0 1 0))
    (setq mp3 (vlax-make-safearray vlax-vbDouble '(0 . 2)))
    (vlax-safearray-fill mp3 '(-1 0 0))
    (setq mLeader2 (vla-mirror mLeader mp1 mp2))
    (setq mLeader (vla-mirror mLeader2 mp1 mp3))
    (vla-delete mLeader2)
Best,
~DD
SAPER59
Thanks CodeDing
I will use it as a solution.
Even do I will try to find how can it be created from the bigining in that mode, without the trick of mirroring, but yours is a very good solution
Thanks again
