Add command in Saveall.lsp
Sandervp
Sandervp
Does anybody know if it's possible to add a command to the Express saveall lisp?
AutoCad must do this command (a lisp command) before it saves all the open drawings.
Or is it possible to create a lisp that will do this command for all the open drawings?
Thank U
Luís Augusto
Using objectDBX you can execute commands and then save the file.
I must point out that for some commands there are restrictions.
See the example below:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/request-for-a-lisp-to-batch-change-a...
What commands do you need to perform?
Best regards, Luís Augusto
Sandervp
Hello Luis Augusto,
I have got a lot of drawings. I need to make an e-transmit of all these drawings.
In the "savealll.lsp" I want to put an own command from another lisp file.
This lisp reloads all the unloaded xrefs, saves the drawing, creates an e-transmit, unloads the last reloaded xrefs and saves the drawing again.
The e-transmit is saved at the same folder as the drawing without the transmittal setupname "-standard" in the drawing filename.
(DEFUN c:EQ ()
(command "_xref"
"r"
(command "_qsave")
(command "_etransmit"
"_c"
(strcat (getvar "dwgprefix")
(substr (getvar "dwgname")
1
(- (strlen (getvar "dwgname")) 3)
"ZIP"
(command "_undo"
"3")
(command "_qsave")
(princ)
I've got also another lisp of this one, with the command "close" at the end.
I want to add the command "EQ" to the saveall lisp. It should be perfect if this lisp creates an e-transmit from all the open drawings, save all these drawings and close all these drawings.
Do the same with all the drawings in a specific folder (without opening every drawing) should be much better than perfect.
Luís Augusto
I have not tested, but maybe this can help.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-etransmit-all-open-file/m-p/606...
Unfortunately, objectDBX has some restrictions:
- No SelectionSets               (ssget, ssname, ssdel, etc)
- No Command Calls               (command "_.line" ... etc)
No ent* methods                (entget, entmod, entupd, etc)
- No Access to System Variables  (setvar, getvar, setvariable, etc)
That way, the only way I know about making broadcasts is with the open document.
I hope the above topic can help you.
