Merging layers from a block to layers in a template automatically.
nickburke
nickburke
We do a lot of inserting of blocks we get from outside sources.  I am wondering if there is a way for the layers in blocks to be automatically converted to layers in my template.  For example: block layer RED change to template layer TOP and so on. We can get it set up so we are always changing the same named block layers to the same layer in the template. Right now I am exploding, then changing to by layer and finally using merge on the blocks to get this done.  I just want to insert the blocks and all that is taken care of without all those clicks.
3wood
You can try CHZ20.
Choose "By File", then select a txt file with predefined layer matching rules.
Settings:
Example of layer matching rules saved in a txt file:
