- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have several mleaders in my drawing. Each of them have text that is in all caps. I want to change the text to title text. I have tried several of the lisp routines found on other sites with no luck. I wouldn't say they completely didn't work. The issue is that I have multiple lines of text in my mleaders. When I use the lisp routines, the top line changes to title text but the rest of the lines are erased.
I am new at posting to forums, please bare with me....
I am attaching the lisp routine that I tried along with two screen shots....the first screen shot (TEXT-1) is before running the lisp. The second screenshot is the result of using the lisp. Why are the 2nd and 3rd lines disappearing? Can anyone fix the current lisp or send me a lisp that will work? Also, I have to pick each mleader individually instead of using a crossing or selecting all. Can this be altered somehow in the lisp as well?
I have posted this in the Civil 3D section and received the following response from ChrisRS...."Since MLEADERs are AutoCAD objects not Civil3D objects, you may have better luck posting in the "AutoCAD" Forum". I hope someone here can help. Thanks in advance !!!!
