set distance by lisp in a dynamic block
R0m3r014
Message 1 of 9
R0m3r014
Hi.
Maybe someone here in this forum can help me.
I'm trying to set the distance for a dynamic block of a single parameter; which is linear and is called Distance1.
I do not know what I'm doing wrong, but I can not do it and change the desired distance.
He helped me with the functions of Lee Mac, but something is wrong. Any help very similar, I will be completely grateful.
(defun c: ddd (/ obj dd)     (if (y (setq obj (car (entsel "\ ndynamic block:")              (setq dd (getdist "\ Length:"))))              (= "AcDbBlockReference" (vla- get-objectname (setq obj (vlax-esame-> vla-object obj))))              (=: vlax-true (vla-get-isdynamicblock obj))         )         (LM: setdynpropvalue obj "Distance1" dd)     )     (princ) )
(defun LM: setdynpropvalue (blk prp val)     (setq prp (strcase prp))     (vl-some        '(lambda (x)             (if (= prp (strcase (vla-get-propertyname x)))                 (progn                     (vla- put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))                     (cond (val) (t))                 )             )         )         (vlax-invoke blk 'getdynamicblockproperties)     ) )
(vl-load-com) (princ)
Replies (8)
Message 2 of 9
Satish_Rajdev
There are so many mistake in your code so I wrote new one, Give a try on this:
(defun c:ddd ( / d o)
  (if (and (setq o (car (entsel "\nSelect Dynamic Block : ")))
	   (setq o (vlax-ename->vla-object o))
	   (if (not (eq (vla-get-objectname o) "AcDbBlockReference"))
	     (alert "Please select block object.")
	     t
	   (if (not (eq (vla-get-isdynamicblock o) :vlax-true))
	     (alert "Please select dynamic block.")
	     t
	   (setq d (getdist "\nSpecify Length : "))
    (LM:setdynpropvalue o "Distance1" (rtos d 2 2))
  (princ)
;; Set Dynamic Block Property Value  -  Lee Mac
;; Modifies the value of a Dynamic Block property (if present)
;; blk - [vla] VLA Dynamic Block Reference object
;; prp - [str] Dynamic Block property name (case-insensitive)
;; val - [any] New value for property
;; Returns: [any] New value if successful, else nil
(defun LM:setdynpropvalue ( blk prp val )
    (vl-some
       '(lambda ( x )
                (progn
                    (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
                    (cond (val) (t))
(vl-load-com)
(princ)
Best Regards,
Satish Rajdev
REY Technologies | Linked IN | YouTube Channel
Message 3 of 9
_gile
The simplest way to get or set dynamic properties is using the getpropertyvalue and setpropertyvalue functions. See >>this reply<< to a recent topic.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 9
R0m3r014
It really works. Thank you very much for the quick answer. regards
Message 5 of 9
R0m3r014
@Satish_Rajdev
That works very well
I just wish I could have a multiple selection of blocks in a selection set.
How can I achieve it?
I appreciate your appreciable help.
Message 6 of 9
_gile
Try this:
(defun c:ddd (/ ss dist i br)
  (if
    (and
      (setq ss (ssget '((0 . "INSERT"))))
      (setq dist (getdist "\nDistance: "))
     (repeat (setq i (sslength ss))
       (setq br (ssname ss (setq i (1- i))))
       (if (= (getpropertyvalue br "IsDynamicBlock") 1)
         (vl-catch-all-apply
           'setpropertyvalue
           (list br "AcDbDynBlockPropertyDistance" dist)
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
R0m3r014
@_gile
your code works for the selection of multiple dynamic blocks.
however, when entering the length, the changes in said dynamic blocks are not applied.
the parameter is still Distance1.
What could be failing?
Message 8 of 9
_gile
Oopss!...
Just replace:
with:
(list br "AcDbDynBlockPropertyDistance1" dist)
Gilles Chanteau
GileCAD
GitHub
Message 9 of 9
R0m3r014
@_gile  That really is what I needed. Thank you very much for your valuable time and support. regards
