Using "vla-InsertBlock" To Insert a Block With a Single Attribute
mgorecki
mgorecki
Hello, I found some code that will allow me to insert a block without using the "(command "insert".....) method because that caused the program to crash on some computers.
(vla-InsertBlock (vla-get-modelspace
     (vla-get-activedocument
      (vlax-get-acad-object)))
  (vlax-3d-point overallHorUnitDimLoc) "Note_Symbol" 1 1 1 0 )
The problem is, the block has an attribute but I don't know how to add the attribute to the vla-InsertBlock command (if it's even possible).
Can someone show me how to do this?
The command I used to use is:
(command "insert" "Note_Symbol" overallHorUnitDimLoc "1" "1" "0" "4") where the "4" was the attribute value.
Mark
_gile
You have to get the Attribute collection of the newly inserted block reference, and as it contains only one attribute just get the first one of the list.
(setq block (vla-InsertBlock
              (vla-get-modelspace
              "Note_Symbol"
              1
              1
              1
              0
;; get the block attributes
(setq attributes (vlax-safearray->list (vlax-variant-value (vla-getAttributes block))))
;; get the first attribute of the list to set its "value" (TextString property)
(vla-put-TextString (car attributes) "4")
Gilles Chanteau
GileCAD
GitHub
mgorecki
That did the trick.  Thank you very much!
