MidLenV1-1 needed update
jyan2000
jyan2000
Hello Forums,
I've using this MidLenV1-1.lsp for long time.. I will need a minor adjustment with this lisp.
Request: The Lisp gives a length ( Exp : 290.155) as set of ddunits. However I want it to be rounded to 290. Is it possible to ammend without changing ddunits setting ?
Best Regards
Victor
ВeekeeCZ
Go to the FIELD dialog, adjust the format as you need, then locate the fmt variable at the top of the code and change it.
Explore, try, learn.
jyan2000
(setq fmt "%lu2%pr0") ;; Field Formatting
Thats it.. Thank u very much for ur guide...
Best regards
Victor
