AUTO UPDATE SMART BLOCK
AIR_123
Message 1 of 9
AIR_123
Hi Guys,
I have issue.
I have a smart block with block properties table inside. Block contains 100ths of parameters.
Sometimes I need to modify block and change parameters in the block table.
The issue is when block editor closed, blocks are not populated with new information immediately.
You have to select the block, choose dropdown arrow and select same predefined configuration of smart block again, in order for changes to be shown.
My question: Is there a way to automate smart block update (or what ever this process should be named), to "reselect" block configuration and show new info from smart block table? Thx
Replies (8)
Message 2 of 9
Moshe-A
@AIR_123 ,
Surly we need some interpetation here 😀
Smart block is a block with attributes? a dynamic block?
parameters is attributes?
block table is AutoCAD table?
to populate changes in attribute block you need to use ATTSYNC or BATTMAN command this will update every attribute properties but not attributes value.
Moshe
Message 3 of 9
AIR_123
Yes. block has attributes. Dynamic block.
Some attributes are parameters in the block table.
Not ACAD table, but block properties table
Table extract look like this
Selection of configuration looks as following
Message 4 of 9
Moshe-A
First, are you aware of ATTSYNC?
Second, dynamic blocks can some times be tricky and need to be replaced them as whole. so maybe for that you need some lisp to read + delete the existing and insert new.
Moshe
Message 5 of 9
AIR_123
yes I'm aware of attsync, but that one only updates attributes.
I have attributes linked with parameters. And parameters don't change with attsync.
yes, that's why I'm on lisp forum to see if there might be programmatic solution to this issue.
Message 6 of 9
Moshe-A
@AIR_123 ,
i do not think there is a general solution to this, it totally depend on your blocks name, attributes tag name, dynamic parameters name it must be tailored for you 🤔
Moshe
Message 7 of 9
dbroad
So you're editing the block table that controls the geometry of the dynamic block and want the changes to be updated in all the block references as soon as you exit bedit? That wouldn't happen automatically as you've discovered. To code a lisp, it depends on whether you would like it to be automatic (involving reactors) or semi-automatic.
Like the others, I don't think there is a solution other than the one you've already found, unless you want to tailor one for a specific block. I don't even think that would work well since editing the block table just changes individual settings and it appears when you insert the block that those settings are related.  You might get better results with a lookout table instead.
Architect, Registered NC, VA, SC, & GA.
Message 8 of 9
Sea-Haven
Dbroad agree with your comments, using bedit you know the "Effective" name of the dynamic block, so you would need to get all dynamic blocks and look at there "effective name" if match then get all current dynamic block properties, delete block and insert a new 1 with correct dynamic  properties.
Message 9 of 9
AIR_123
OK guys, clear. Not a simple task.
I was thinking of following logic in the script
Select block by name
Loop over ID's
Reassign (re-select) configuration option
Is that something can be implemented?
