Merry Christmas 2017
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I dug this out of my archives...
It is once again offered with respect to and in celebration of all faiths. It was just for fun.
WARNING: Do NOT run this routine on anything but an empty (or disposable) drawing, or QUIT after running.
;;AUTOCAD PROGRAMMING CHALLENGE NO. 2 ;;C:XMASTREE ;;John F. Uhden, CADvantage Custom Utilities ;;CADvantage@compuserve.com ;;12-11-97 ;;Note (12-08-02): ;; Jim Fisher recalls better than I the rules of this ;; programming challenge on the old ACAD Forum. ;; Technically, this exceeded limitations and should ;; have been disqualified. Dietmar Rudolph's was ;; technically correct and pretty darn nifty. Too ;; bad I don't have a copy to share. In fact, we can ;; thank Jim for retrieving this from his archives. ;; Anyway, it's still cute. ;;Revised (12-08-02) for R15+ ;; Added vl-cmdf, UCSICON=0, and SHADE command only. ;; Try setting SHADEMODE to different values before running, ;; and then use the 3DORBIT command after. ;; HAPPY HOLIDAYS! (defun c:XMASTREE (/ rad R N Z dZ a da d H I J K +- s c) (setq c (if (>= (getvar "acadver") "15") vl-cmdf command)) (setq d distance s setvar)(s "CMDECHO" 0)(s "UCSICON" 0) (s "TILEMODE" 1)(s "UCSFOLLOW" 0)(s "HIGHLIGHT" 0) (s "REGENMODE" 1)(c "_.LINE""0,0""1,1""")(c "_.ZOOM""_E") (C"_.LAYER""_U""*""")(C"_.ERASE"(ssget"X")"")(c"_.UCS""_W") (C "_.VPOINT""-3,-3,1.2")(C "_.ZOOM""_C""0,0,7" 15) (defun rad (Z)(* 0.75 (sqrt (- 12.0 Z)))) (setq N 25 Z 1.0 dZ 0.5 a 0.0 da (/ pi N) hpi (* pi 0.5)) (while (< Z 12.0)(setq R (rad Z))(repeat N (setq +- (if (= +- -) + -) H (list 0.0 0.0 (+- Z (* dz 0.25))) I (polar H a R) a (+ a da) I (mapcar '+ I (list 0.0 0.0 (* dZ 0.5))) J (polar H a (+ R R)) a (+ a da) J (mapcar '+ J (list 0.0 0.0 dZ)) K (polar H a R) K (mapcar '+ K (list 0.0 0.0 (* dZ 0.1)))) (entmake (list '(0 . "3DFACE")'(62 . 3)'(70 . 0) (cons 10 H)(cons 11 I)(cons 12 J)(cons 13 K))) (if (and (zerop (rem (1- Z) 1))(zerop (rem N 5)))(progn (entmake (list '(0 . "CIRCLE")(cons 10 J)'(40 . 0.07) '(39 . 0.35)'(62 . 255)))(prompt " HO") (setq J (mapcar '+ J (list 0.0 0.0 0.4))) (entmake (list '(0 . "3DFACE")'(62 . 2)'(70 . 0) (cons 10 (polar J (+ a hpi)(* (d I K) 0.2))) (cons 11 (polar J (- a hpi)(* (d I K) 0.2))) (cons 12 (mapcar '+ J (list 0.0 0.0 (* dZ 0.5)))) (cons 13 (mapcar '+ J (list 0.0 0.0 (* dZ 0.5)))))) )))(terpri)(setq Z (+ Z dZ) a (+ a (/ da 2)))) (entmake '((0 . "3DFACE")(62 . 7)(10 -0.536 0.57073 13.225) (11 0.5123 -0.545566 13.225)(12 -0.011815 0.012582 12.6687) (13 -0.0118153 0.012582 12.6687)(70 . 0))) (entmake '((0 . "3DFACE")(62 . 7)(10 -0.3357 0.3575 12.325) (11 -0.0118 0.01258 13.7813) (12 0.18839 -0.200611 12.8812) (13 0.188387 -0.200611 12.8812) (70 . 0))) (entmake '((0 . "3DFACE")(62 . 7)(10 -0.536 0.57073 13.225) (11 0.31212 -0.33237 12.3249) (12 0.111916 -0.11918 13.225) (13 0.111916 -0.119179 13.225) (70 . 0))) (c "_.SHADE")(setvar "cmdecho" 1)(alert "\nMerry Christmas!") (princ))
John F. Uhden
