Revision Cloud
Revision Cloud
Tony_Gibbs
Revision Cloud
Tony_Gibbs
Our office only uses 1 set of settings to create a Rev Cloud. Is there a way I can write this into a Lisp file using the Autocad Revision Cloud command "revcloud"?
Example: (c:_revcloud "A" 4.5 "P" pause)
A being for Arc size & P for Polygonals
Thank you
Tony
Ranjit_Singh
Maybe like this
(defun c:somefunc ( / )
(initcommandversion)
(command-s "._revcloud" "_a" 4.5 4.5 "_p"))
trevor.bird.au
Hi Tony,
I hope this helps.
I first save the values of the system variables that REVCLOUD uses and then set your required values before running the command.
The system variables are restored after REVCLOUD is finished.
Trevor
;;  TonysRevCloud.lsp by Trevor Bird
;;  2017-12-16
(defun c:tonysrevcloud
    sv_cmdecho
    sv_revcloudarcstyle
    sv_revcloudcreatemode
    sv_revcloudmaxarclength
    sv_revcloudminarclength
  (setq sv_cmdecho              (getvar 'CMDECHO)
        sv_revcloudarcstyle     (getvar '*REVCLOUDARCSTYLE)
        sv_revcloudminarclength (getvar '*REVCLOUDMINARCLENGTH)
        sv_revcloudmaxarclength (getvar '*REVCLOUDMAXARCLENGTH)
        sv_revcloudcreatemode   (getvar 'REVCLOUDCREATEMODE)
  );setq
  (setvar '*REVCLOUDMINARCLENGTH 4.5)
  (setvar '*REVCLOUDMAXARCLENGTH 4.5)
;  (setvar '*REVCLOUDARCSTYLE "Calligraphy")
  (setvar '*REVCLOUDARCSTYLE "Normal")
  ;;  REVCLOUDCREATEMODE (System Variable)
  ;;  Specifies the default input for creation of revision clouds.
  ;;  Type:  Integer
  ;;  Saved in:  Registry
  ;;  Initial value:  1
  ;;  Value  =  Description
  ;;    0    =  Freehand
  ;;    1    =  Rectangular
  ;;    2    =  Polygonal
  (setvar 'REVCLOUDCREATEMODE 2)
  (setvar 'CMDECHO 1)
  (vl-cmdf "_.REVCLOUD" pause)
  (setvar 'CMDECHO sv_cmdecho)
  (setvar '*REVCLOUDARCSTYLE sv_revcloudarcstyle)
  (setvar '*REVCLOUDMINARCLENGTH sv_revcloudminarclength)
  (setvar '*REVCLOUDMAXARCLENGTH sv_revcloudmaxarclength)
  (setvar 'REVCLOUDCREATEMODE sv_revcloudcreatemode)
  (princ)
);c:tonysrevcloud
(princ "\nTonysRevCloud loaded. Start command with TONYSREVCLOUD.")
(princ)
Trevor
DanielLench_
@trevor.bird.au, @Tony_Gibbs@Ranjit_Singh,
My company also uses a standard arc length and style, with the addition of a standard layer "CLOUD" and polyline width "0.3".
The issue now, I believe, is the change to the REVCLOUD object from 2021. Would you be kind enough to double check the lsp for compatibility regarding the update? If you can add in the polyline width and layer, that would really fill out this tool. Thank you for your consideration and time.
