Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been running a Lisp routine that creates drawings from reading a *.txt file. Inserts a drawing template/executes several commands then w/block to a file/next record repeat. AutoCAD crashes after about 700 drawings made +/- (the *.txt file has about 4300+ records -1 per drawing).
Anyway, I think it is a memory problem? Maybe with my laptop or is there a setting in AutoCAD?
I have Dell Precision 3530 Laptop/Windows 10 Pro 64-bit/32GB RAM. AutoCAD 2019 64bit.
Any help would be appreciated. I'm not sure how to go about changing memory settings on the Laptop or AutoCAD.
Thank you,
Jack
