DRAW ALL LINETYPES
DRAW ALL LINETYPES
arpansark0544TCX
DRAW ALL LINETYPES
arpansark0544TCX
Dear all,
Is there a way to draw all the line types available on the same layer as the line type name?
For eg. -HT- line type with the name HT LINE shall be in the layer  HT LINE.
Thank you.
hak_vz
Create layers with used linetype names. Use quickselect, select entities according to particular linetype and change layers to already created object to particular layer in properties tab. Creating lisp file is not needed. You just have to make your drawing according to the standard you want to apply. Start learning lisp and you can create your own functions that will do what you want.
Miljenko Hatlak
