Mapcar returning nilnil - Full code in post and attached
bobbyrubyii
Message 1 of 8
bobbyrubyii
(full in development code can be found below snippets)
  I am writing a program to analyze my pole sheets based of certain rules to tell me if they have any safety violations.
To do this I must breakdown the the measurements taken from the field into inches.  I am trying to utilize the mapcar function for this but it is not returning the expected value.
I have tested the code within the function convertToInches and it works... I'm just cleaning up the code so I can call the function convertToInches instead of copy and paste it in several areas within it needing to changes variables and such.
Trying to understand why the code below in red is not returning a list of inches within pwr_hgts_in
(setq pwr_hgts_in(mapcar 'convertToInches ' (pwr_hgts)))
(defun convertToInches ( listItem )
	(setq listItem_in(vl-string-left-trim "-" (vl-string-left-trim "0123456789" listItem)))
	(setq listItem_ft(vl-string-right-trim "-" (vl-string-right-trim "0123456789" listItem)))
	(setq listItem (+ (* 12 (atoi listItem_ft)) (atoi listItem_in)))
FULL CODE
;FMRP
;Description: A program determine if poles need make ready or not.
;pwg_hgts - list of pwr heights from attribute data
;( n sec dl r trns)
;pwg_hgts_in - list of pwr heights in inches
;( n sec dl r trns)
;lwst_pwr - contains lowest power measurement
;lwst_pwr_in- lowest power in inches.
;comm_hgts - list of communication heights from highest to lowest.
;comm_hgts_in - list of communication heights from highest to lowest in inches.
;comm_owners - list of communication facility owners
;diff = Difference between highest communication and lowest power.
;phoa = proposed height of attachment
(defun c:REC-FMRP ( /
	       profile_nu
	       pwr_hgts
	       pwr_hgts_in
	       lwst_pwr
	       lwst_pwr_in
	       comm_hgts
	       comm_hgts_in
		   comm_owners
	       diff
	       phoa
	       phoa_i
	       mr
	       i
	       j
	       p
	       s )
	(prompt ";\n
;Description: A program to determine poles which will need make ready performed.
    (setq p "ACMAP_ANN_TEMPLATE_REC_POLE_SHEET"; Block name pattern
          p (strcase p)
	 (if (setq s
			(ssget "_X"
				(list
					'(0 . "INSERT")
					(cons 2
						(strcat "`*U*," p)
		);if blocks found and selection set is set
	    ;keep the blocks vs the pattern provided
		(repeat (setq i (sslength s))
            (if
				(not
					(wcmatch
						(strcase
							(LM:blockname
								(vlax-ename->vla-object
									(ssname s
										(setq i
											(1- i)
							);add to selection set
						p
                (ssdel (ssname s i) s) ;delete item - didn't match pattern
            );if they do not match the pattern delete it from the selection set, if they do keep them
		);iterate through the blocks
	(if s
        (repeat (setq j (sslength s)) ;iterate through the blocks
			(setq j (1- j))
			(setq profile_nu (LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "PROFILE_NU"))
			(setq pwr_hgts
				(list
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "N_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "SEC_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "DL_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "R_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "T_HGT")
			(setq pwr_hgts (vl-remove "" pwr_hgts))
			(setq pwr_hgts (ME:remove-nil pwr_hgts))
			(setq comm_owners
				(list
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM1OWN")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM2OWN")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM3OWN")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM4OWN")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM5OWN")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM6OWN")
			(setq comm_owners (vl-remove "" comm_owners))
			(setq comm_owners (ME:remove-nil comm_owners))
			(setq comm_hgts
				(list
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM_1_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM_2_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM_3_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM_4_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM_5_HGT")
					(LM:vl-getattributevalue (vlax-ename->vla-object (ssname s j)) "COM_6_HGT")
			(setq comm_hgts (vl-remove "" comm_hgts))
			(setq comm_hgts (ME:remove-nil comm_hgts))
			(prompt (strcat "The lowest power / highest communication for " profile_nu " are " pwr_hgt " / " pvd_2_hgt " respectively\n"))
			 ;get inches and feet sides of dash
			 (setq pwr_hgt_i(vl-string-left-trim "-" (vl-string-left-trim "0123456789" pwr_hgt)))
			 (setq pwr_hgt_f(vl-string-right-trim "-" (vl-string-right-trim "0123456789" pwr_hgt)))
			 (setq pvd_2_hgt_i(vl-string-left-trim "-" (vl-string-left-trim "0123456789" pvd_2_hgt)))
			 (setq pvd_2_hgt_f(vl-string-right-trim "-" (vl-string-right-trim "0123456789" pvd_2_hgt)))
			 ;convert feet heights to inches and add the "i" variable respectively - reassign value to orginal vars
			(setq pwr_hgt (+ (* 12 (atoi pwr_hgt_f)) (atoi pwr_hgt_i)))
			(setq pvd_2_hgt (+ (* 12 (atoi pvd_2_hgt_f)) (atoi pvd_2_hgt_i)))
			;set phoa and phoa_i
			(setq phoa (strcat (itoa (/ (+ pvd_2_hgt 12) 12)) "-" (itoa (rem (+ pvd_2_hgt 12) 12))))
			(setq phoa_i (+ pvd_2_hgt 12))
			(prompt (strcat "The proposed HOA to test against for " profile_nu " is " phoa "\n"))
			;calculate difference between phoa and lwst power
			;if the difference is less than 40 flag for make ready
			(if (< (- pwr_hgt phoa_i) 40)
			  (prompt (setq mr "Needs MR\n"))
			  (prompt (setq mr "No MR Needed\n"))
    (princ)
);defun FMRP
;Lee Mac's orginial code edited from here... Answer -> http://www.cadtutor.net/forum/showthread.php?89306-Lisp-to-select-blocks-using-wildcard
;; Block Name  -  Lee Mac
;; Returns the true (effective) name of a supplied block reference
(defun LM:blockname ( obj )
    (if (vlax-property-available-p obj 'effectivename)
        (defun LM:blockname ( obj ) (vla-get-effectivename obj))
        (defun LM:blockname ( obj ) (vla-get-name obj))
    (LM:blockname obj)
(vl-load-com) (princ)
;; Get Attributes  -  Lee Mac
;; Returns an association list of attributes present in the supplied block.
;; blk - [vla] VLA Block Reference Object
;; Returns: [lst] Association list of ((<Tag> . <Value>) ... )
(defun LM:vl-getattributes ( blk )
    (mapcar '(lambda ( att ) (cons (vla-get-tagstring att) (vla-get-textstring att)))
        (vlax-invoke blk 'getattributes)
;; Get Attribute Value  -  Lee Mac
;; Returns the value held by the specified tag within the supplied block, if present.
;; tag - [str] Attribute TagString
;; Returns: [str] Attribute value, else nil if tag is not found.
(defun LM:vl-getattributevalue ( blk tag )
    (setq tag (strcase tag))
    (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att)))
;; Set Attribute Value  -  Lee Mac
;; Sets the value of the first attribute with the given tag found within the block, if present.
;; val - [str] Attribute Value
;; Returns: [str] Attribute value if successful, else nil.
(defun LM:vl-setattributevalue ( blk tag val )
    (vl-some
       '(lambda ( att )
                (progn (vla-put-textstring att val) val)
; remove nil from list
(defun ME:remove-nil ( a_list )
	(apply 'append
		(mapcar
			'(lambda (item)
			(if (not (null item))
			(list item)
		a_list)
Replies (7)
Message 2 of 8
cadffm
 Without test and reading the rest of that code.
 (setq pwr_hgts_in (mapcar 'convertToInch pwr_hgts))
Sebastian
Message 3 of 8
dlanorh
What is pwr_hgts? a variable? a variable containing a list?
There is what looks like a spurious " ' " in your mapcar. '(pwr_hts) does NOT turn pwr_hts into a list needed for mapcar it means what follows is taken literally i.e. (pwr_hts) which isn't anything as far as I can see.
I am not one of the robots you're looking for
Message 4 of 8
ВeekeeCZ
I've tried the code...  @cadffm is correct....
...but there must be some another loop missing in your code.
It runs until this line:
then it fails because pwr_hgt and pvd_2_hgt are nil. These variables are never mentioned in the code before.
pwr_hgt is obviously a member of pwr_ghts, but pvd_2_hgt is a member of comm_hgts?
and BTW, you really shouldn't convert the same ename to obj so many times... use another variable... o/obj/itm?
      (setq o (vlax-ename->vla-object (ssname s (setq j (1- j)))))
      (setq profile_nu (LM:vl-getattributevalue o "PROFILE_NU"))
      (setq pwr_hgts
	     (list
	       (LM:vl-getattributevalue o "N_HGT")
	       (LM:vl-getattributevalue o "SEC_HGT")
Message 5 of 8
bobbyrubyii
Apologies I should have explained there was still code where I expected it to go.  I am re-writing a previous "proof on concept" version that was for another power company we permit for attachment to.
Message 6 of 8
bobbyrubyii
accepted because of explanation
Message 7 of 8
bobbyrubyii
I am still not getting the overall desired result which is a list of converted measurements into inches.  I am very confused.  At this point I am going back to not using the function.
Message 8 of 8
dlanorh
Any chance of posting the drawing in Autocad2010 format?
