how to restore snap setting
Message 1 of 14
Hello guys,
The lisp below erases my snap settings,
After I set my snap settings to be all selected:
like this
I run this lisp and it deselect all the object snap.
Can you update this code so it will keep the settings that I made?
the code:
(defun c:LD  (/ f curlayer curosmode ent exit a b spaces spaces1 testlst vlaobj1 vlaobj2 x y z)
  (while (setq vlaObj1   (vlax-ename->vla-object (setq ent (car (entsel))))
               vlaObj2   (vlax-ename->vla-object (car (entsel)))
               curlayer  (getvar 'clayer)
               curosmode (getvar 'osmode)
               spaces1   (getreal "\nEnter number of spaces: "))
    (cond ((or (minusp spaces1) (< spaces1 1)) "Spaces should be greater than 1")
          (T
           (setvar 'clayer (cdr (assoc 8 (entget ent))))
           (setvar 'osmode 16384)
           (setq spaces  (test spaces1 ())
                 testlst (vl-sort
                           (apply
                             'append
                             (mapcar
                               '(lambda (y)
                                  (mapcar '(lambda (x) (append (append (list (distance x y)) (list x)) (list y)))
                                          (list (vlax-curve-getStartPoint vlaObj1)
                                                (vlax-curve-getEndPoint vlaObj1))))
                               (list (vlax-curve-getStartPoint vlaObj2)
                                     (vlax-curve-getEndPoint vlaObj2))))
                           '(lambda (x y) (< (car x) (car y))))
                 a       (cdar testlst)
                 b       (cdr (apply 'append
                                     (car (mapcar '(lambda (y)
        (if (not (or (equal (cadar testlst) (cadr x) y)
        (equal (caddar testlst) (caddr x) y)
        (equal (cadar testlst) (caddr x) y)
        (equal (caddar testlst) (cadr x) y)))
        x))
                                                             testlst))
                                                  (list 1e-15))))))
           (command "._undo" "_begin")
           (test2 a b spaces1 spaces)
           (command "._undo" "_end")
           (initget "Yes No")
           (setq f (cond ((getkword "\nFLip lines [Yes/No] <No>: "))
                         ("No")))
           (cond ((wcmatch f "Yes,Y")
                  (command "._undo" 1)
                  (setq z (last a))
                  (setq a (cons (car a) (cdr b)))
                  (setq b (cons (car b) (list z)))
                  (test2 a b spaces1 spaces))
                 (T ())))))
  (setvar 'clayer curlayer)
  (setvar 'osmode curosmode))
(defun test  (x y)
  (cond ((< x 1) y)
        (T (test (fix (- x 1)) (cons (fix x) y)))))
(defun test2  (a b c d)
  (mapcar '(lambda (x y) (command-s "._pline" x y ""))
          (mapcar '(lambda (x) (polar (car a) (angle (car a) (cadr a)) (* (/ (distance (car a) (cadr a)) c) x)))
                  (if (not (zerop (rem c (fix c))))
                    d
                    (cdr (reverse d))))
          (mapcar '(lambda (x) (polar (car b) (angle (car b) (cadr b)) (* (/ (distance (car b) (cadr b)) c) x)))
                    d
                    (cdr (reverse d))))))
Thank you,
Eyal
Replies (13)
Message 2 of 14
dbhunia
Hi
Try this
(setq osm (getvar 'osmode))
          (T
                 testlst (vl-sort
                           (apply
                             'append
                             (mapcar
                               '(lambda (y)
                 a       (cdar testlst)
        x))
                                                             testlst))
                                                  (list 1e-15))))))
           (initget "Yes No")
                         ("No")))
                  (setq z (last a))
                 (T ())))))
  ;(setvar 'osmode curosmode))
  (setvar 'osmode osm))
(defun test  (x y)
  (cond ((< x 1) y)
                    d
                    (cdr (reverse d))))
                    d
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 14
Hi @dbhunia ,
I run your lisp and it didn't work, I still get This,
Do you have another idea how to select all like This,
Usually I work with object snap all selected.
Thank you,
Eyal
Message 4 of 14
dbhunia
Can you send me a sample drawing in AutoCAD 2007 format...... to test
Another thing state briefly what lisp do......
Debashis Bhunia
Message 5 of 14
dlanorh
@Anonymous wrote:
Hello guys,
like this
the code:
               ;curosmode (getvar 'osmode)
          (T
                 testlst (vl-sort
                           (apply
                             'append
                             (mapcar
                               '(lambda (y)
                 a       (cdar testlst)
        x))
                                                             testlst))
                                                  (list 1e-15))))))
           (initget "Yes No")
                         ("No")))
                  (setq z (last a))
                 (T ())))))
(defun test (x y) (cond ((< x 1) y) (T (test (fix (- x 1)) (cons (fix x) y))))) (defun test2 (a b c d) (mapcar '(lambda (x y) (command-s "._pline" x y "")) (mapcar '(lambda (x) (polar (car a) (angle (car a) (cadr a)) (* (/ (distance (car a) (cadr a)) c) x))) (if (not (zerop (rem c (fix c)))) d (cdr (reverse d)))) (mapcar '(lambda (x) (polar (car b) (angle (car b) (cadr b)) (* (/ (distance (car b) (cadr b)) c) x))) (if (not (zerop (rem c (fix c)))) d (cdr (reverse d))))))
Thank you,
Eyal
You are saving the entry state, changing to all on, then restoring the entry state. So comment out the two red lines as indicated should preserve the "all on state"
I am not one of the robots you're looking for
Message 6 of 14
hello @dbhunia,
I have no drawing to send because it happens even with new drawing:
these are my steps:
1. I draw 2 lines.
2. I make sure that the object snap settings are like: this.
3. I run the lisp. ( entering LD in the command prompt)
4. I check again the object snap settings and it is like:this.
I hope I'm clear enough.
Eyal.
Message 7 of 14
dlanorh
Try this
  (setvar curosmode (getvar 'osmode))
  (setvar curlayer  (getvar 'clayer))
          (T
                 testlst (vl-sort
                           (apply
                             'append
                             (mapcar
                               '(lambda (y)
                 a       (cdar testlst)
        x))
                                                             testlst))
                                                  (list 1e-15))))))
           (initget "Yes No")
                         ("No")))
                  (setq z (last a))
                 (T ())))))
(defun test  (x y)
  (cond ((< x 1) y)
                    d
                    (cdr (reverse d))))
                    d
You were continually saving 'clayer and 'osmode within a while loop which may have been the problem. Re your post for this to work everything must be "ON" before running the lisp.
Message 8 of 14
phanaem
You have to get the settings outside the loop, as dbhunia suggested. Also, your while condition will generate an error if nothing is selected, so the lisp will exit without restoring the initial settings.
Replace this
with this
(defun c:LD  (/ f curlayer curosmode ent ent2 a b spaces spaces1 testlst vlaobj1 vlaobj2 x y z)
  (setq
  (while (and
           (setq ent2 (car (entsel)))
           (setq spaces1 (getreal "\nEnter number of spaces: "))
    (setq vlaObj1  (vlax-ename->vla-object ent)
          vlaObj2  (vlax-ename->vla-object ent2)
Message 9 of 14
cadffm
To set osmode to 16384 is stupid like set to 0.
If osmode is lower then 16384 (=on) you have ADD 16384 to the current osmode.
and later, if osmode was lower then 16384 before, you should remove 16384.
Thats how osnap disableing works, on/off, osmode/osmode+16384.
But this (command) statement doesn't  interactive with users, so the best way is to ignore osnaps totally.
Remove all setvar-getvar-osmode and handle the object-snap in your command by using explicit the _NON option.
Or simply makr sure your osnapcoord is set to 1.
Both ways don't touch osmode, so haven't never  trouble with it.
And at last.
@Anonymous
All object snaps on, really?
I would have trouble with running osnap
Geometric CEnter always on,
and running osnap would me slowing down if need to draw accurately.
Interesting setting.
Sebastian
Message 10 of 14
dbhunia
Hi
Try with this.....
          (T
                 testlst (vl-sort
                           (apply
                             'append
                             (mapcar
                               '(lambda (y)
                 a       (cdar testlst)
        x))
                                                             testlst))
                                                  (list 1e-15))))))
           (initget "Yes No")
                         ("No")))
                  (setq z (last a))
                 (T ()))))
;(setvar 'clayer curlayer)
(defun test  (x y)
  (cond ((< x 1) y)
                    d
                    (cdr (reverse d))))
                    d
                    (cdr (reverse d))))
Debashis Bhunia
Message 11 of 14
Great!!! @dbhunia thank you , it works great.
Thank you all for your help!!
Message 12 of 14
ВeekeeCZ
Hmm, this thread is a sad story to read. Good suggestions are ignored, poor solution is accepted. 😞
And @dlanorh had a bad moment.
Message 13 of 14
dlanorh
I'm sure I typed (setq...), but then I'm old. These "senior" moments will increase in frequency until they merge all together. Robot Sad Robot tongue
Message 14 of 14
Hi @ВeekeeCZ , I'm sorry you feel this.
maybe @dlanorh has good ideas too , but the suggestion @dbhunia gave me , worked exactly for what I needed.
So please don't be upset about accepting other ideas. YOU ARE ALL VERY HELPFULL!!
GOOD DAY!
Eyal.
