Add Prefix and Suffix option to lisp routine
jtm2020hyo
jtm2020hyo
this lisp works like "tcount.lsp" but just in block-attributes, this lisp works great but I need options like Suffix and Prefix.
Can anyone help me?
(defun c:tcount_att (/ ss ob start_num inc_num sum ename new_value OLDER *error*)
  (vl-load-com)
  (setq OLDER *error*
	*error* myerror)
  (if (setq ss (ssget '((0 . "INSERT"))))
    (progn
      (initget 1 "X Y Select")
      (setq ob (getkword "\nSort selected objects by [X/Y/Select-order] <Select-order>: "))
      (cond
	((= ob "X")
	 (setq ss (sort_x ss))
	((= ob "Y")
	 (setq ss (sort_y ss))
	((= ob "Select")
	 (setq ss (sort ss))
	);cond
      (setq start_num (getint "\nSpecify starting number <1>: "))
      (if (= start_num nil)
	(setq start_num 1)
	(setq start_num start_num)
      (setq inc_num (getint "\nSpecify increment number <1>: "))
      (if (= inc_num nil)
	(setq inc_num 1)
	(setq inc_num inc_num)
	);if
      (setq sum 0)
      (setq sum (apply '+ (list sum start_num)))
      (setq ename (entnext (car ss)))
      (if (/= (cdr (assoc 0 (entget ename))) "SEQEND")
	(progn
	  (setq new_value (rtos sum 2 0))
	  (entmod (subst (cons 1 new_value) (assoc 1 (entget ename)) (entget ename)))
	  (entupd (car ss))
      (mapcar '(lambda (obj)
		 (setq sum (apply '+ (list sum inc_num)))
		 (setq ename (entnext obj))
		   (progn
		     (entupd obj)
	      (cdr ss)
      );progn
    );if
  (setq *error* OLDER)
  (princ)
  );defun
(defun sort_x (ss / n ss1 )
  (setq ss1 nil)
  (setq n 0)
  (repeat (sslength ss)
    (setq ss1 (append ss1 (list (ssname ss n))))
    (setq n (1+ n))
    );repeat
  (setq ss1 (vl-sort ss1 '(lambda (e1 e2) (< (car (cdr (assoc 10 (entget e1))))
					     (car (cdr (assoc 10 (entget e2))))
	);setq
(defun sort_y (ss / n ss1 )
  (setq ss1 nil)
  (setq n 0)
    (setq n (1+ n))
  (setq ss1 (vl-sort ss1 '(lambda (e1 e2) (< (cadr (cdr (assoc 10 (entget e1))))
					     (cadr (cdr (assoc 10 (entget e2))))
	);setq
(defun sort (sset / n ss1 )
  (setq ss1 nil)
  (setq n 0)
    (setq n (1+ n))
  ss1
(defun myerror (s)
  (cond
    ((= s "quit / exit abort") (princ))
    ((/= s "Function cancelled") (princ (strcat "\nError: " s)))
  (princ)
Satish_Rajdev
Try this, Highlighted lines are modified :
(defun c:tcount_att (/ ss ob start_num inc_num sum ename new_value OLDER *error* pre suf)
  (vl-load-com)
  (setq OLDER *error*
	*error* myerror)
  (if (and (setq ss (ssget '((0 . "INSERT"))))
	   (if (not (setq pre (getstring t "\nSpecify Prefix : ")))
	     pre
	   (if (not (setq suf (getstring t "\nSpecify Suffix : ")))
	     suf
    (progn
      (cond
	((= ob "X")
	((= ob "Y")
	((= ob "Select")
	 (setq ss (sort ss))
	);cond
	(setq start_num 1)
      (if (= inc_num nil)
	(setq inc_num 1)
	);if
      (setq sum 0)
	(progn
	  (entupd (car ss))
		   (progn
		     (setq new_value (strcat pre (rtos sum 2 0) suf))
		     (entupd obj)
	      (cdr ss)
      );progn
    );if
  (princ)
  );defun
Best Regards,
Satish Rajdev
REY Technologies | Linked IN | YouTube Channel
dbhunia
Hi
Try this....
  (vl-load-com)
  (setq OLDER *error*
	*error* myerror)
    (progn
      (initget "X Y Picked")
      (setq ob (getkword "\nSort selected objects by [X/Y/Picked-order] <Picked-order>: "))
      (cond
	((= ob "X")
	((= ob "Y")
	((or (= ob "Picked") (= ob nil))
	 (setq ss (sort ss))
      );cond
	(setq start_num 1)
      );if
      (if (= inc_num nil)
	(setq inc_num 1)
      );if
      (setq sum 0)
	(progn
	(initget "Overwrite Prefix Suffix")
		(progn
		(setq ob1 (getkword "\nPlacement of numbers in text [Overwrite/Prefix/Suffix] <Overwrite>: "))
		  (cond
		    ((or (= ob1 "Overwrite") (= ob1 nil))
	  		(entupd (car ss))
		    ((= ob1 "Prefix")
		  	(entmod (subst (cons 1 (strcat new_value (cdr (assoc 1 (entget ename))))) (assoc 1 (entget ename)) (entget ename)))
	  		(entupd (car ss))
		    ((= ob1 "Suffix")
		  	(entmod (subst (cons 1 (strcat (cdr (assoc 1 (entget ename))) new_value)) (assoc 1 (entget ename)) (entget ename)))
		  	(entupd (car ss))
		  );cond
		);progn
	    );if
	);progn
		(progn
		  (cond
		  	(entupd (car ss))
		    ((= ob1 "Prefix")
		  	(entupd (car ss))
		    ((= ob1 "Suffix")
		  	(entupd (car ss))
		  );cond
		);progn
	      (cdr ss)
      );progn
    );if
  (princ)
  );defun
  (setq ss1 nil)
  (setq n 0)
    (setq n (1+ n))
    );repeat
	);setq
  (setq ss1 nil)
  (setq n 0)
    (setq n (1+ n))
	);setq
  (setq ss1 nil)
  (setq n 0)
    (setq n (1+ n))
  ss1
(defun myerror (s)
  (cond
  (princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
dbhunia
Hi
I may be wrong in my last post for your requirement........
If so you can try this......
  (vl-load-com)
  (setq OLDER *error*
	*error* myerror)
    (progn
      (cond
	((= ob "X")
	((= ob "Y")
	 (setq ss (sort ss))
      );cond
	(setq start_num 1)
      );if
      (if (= inc_num nil)
	(setq inc_num 1)
      );if
      (setq sum 0)
	(progn
	(initget "None Prefix Suffix")
		(progn
		(setq ob1 (getkword "\nAdd text with Value to [Prefix/Suffix/None] <None>: "))
		  (cond
		    ((or (= ob1 "None") (= ob1 nil))
	  		(entupd (car ss))
		    ((= ob1 "Prefix")
			(setq Txt (getstring "\nEnter text for Prefix: "))
		  	(entmod (subst (cons 1 (strcat Txt new_value)) (assoc 1 (entget ename)) (entget ename)))
	  		(entupd (car ss))
		    ((= ob1 "Suffix")
			(setq Txt (getstring "\nEnter text for Suffix: "))
		  	(entmod (subst (cons 1 (strcat new_value Txt)) (assoc 1 (entget ename)) (entget ename)))
		  	(entupd (car ss))
		  );cond
		);progn
	    );if
	);progn
		(progn
		  (cond
		  	(entupd (car ss))
		    ((= ob1 "Prefix")
		  	(entupd (car ss))
		    ((= ob1 "Suffix")
		  	(entupd (car ss))
		  );cond
		);progn
	      (cdr ss)
      );progn
    );if
  (princ)
  );defun
  (setq ss1 nil)
  (setq n 0)
    (setq n (1+ n))
    );repeat
	);setq
  (setq ss1 nil)
  (setq n 0)
    (setq n (1+ n))
	);setq
  (setq ss1 nil)
  (setq n 0)
    (setq n (1+ n))
  ss1
(defun myerror (s)
  (cond
  (princ)
Debashis Bhunia
jtm2020hyo
@dbhunia
Both codes are very good and work for me.
thanks a lot, you are the best.
jtm2020hyo
I was testing code but does not work.
