mapcar querry
mapcar querry
vishshreevT578L
Message 1 of 15
mapcar querry
vishshreevT578L
(setq a '(1 2 3 4 5) (1 2 3 4 5) In tutorials to add 1 to list a is (mapcar '1+ a) (2 3 4 5 6) but i want to add 2 to my list a please help
Shreev
Replies (14)
Message 2 of 15
Try
(mapcar '(lambda (x) (+ 2 x)) a)
^_^
Message 3 of 15
vishshreevT578L
Can you suggest me the website to start learning autolisp and vl
Shreev
Message 4 of 15
Ha ha,
This forum and google search to learn.
Search single funtion to learn.
^_^
Message 5 of 15
vishshreevT578L
Sir,
I understand i know just little of autolisp.
Please become a teacher and guide me.
So that i can also start writing small scripts.
Shreev
Message 6 of 15
You can search script in this forum.
Please search "word" before creat new topic.
^_^
Message 7 of 15
vishshreevT578L
But is there any tutorial
Shreev
Message 8 of 15
And
search google what you need
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=autolisp%20tutorial
Keyword very importan.
^_^
Message 9 of 15
vishshreevT578L
Thank you sir
Shreev
Message 10 of 15
you're welcome.
and post your question if not found.
^_^
Message 11 of 15
Kent1Cooper
In this specific case, another rather simple way to do it is to just add 1 to each one twice:
Command: (setq a '(1 2 3 4 5))
(1 2 3 4 5)
Command: (mapcar '1+ (mapcar '1+ a))
(3 4 5 6 7)
But that approach would get cumbersome quickly if you need to add larger numbers to those in the list -- @Anonymous's suggestion in Post 2 is really the way to go, because the only change would be in the 2, and the rest of the code doesn't need to get any longer.
Kent Cooper, AIA
Message 12 of 15
patrick_35
Hi
An another
(setq lst1 '(1 2 3 4 5))
(setq lst2 '(1 2 3 4 5))
(mapcar '(lambda(a b) (+ a b)) lst1 lst2)
Message 13 of 15
Kent1Cooper
@patrick_35 wrote:
An another
That results in (2 4 6 8 10), adding each number to itself.  That result can be obtained more simply from those two lists:
(mapcar '+ lst1 lst2)
But to get what they're looking for -- adding 2 to each number in the original list [the equivalent of applying the (1+) function to each number as in Post 1, but adding 2 rather than 1] -- with this approach, the 'lst2' variable would need to be set to:
'(2 2 2 2 2)
rather than the same as 'lst1'.
Kent Cooper, AIA
Message 14 of 15
Kent1Cooper
[It seems to me that Post 2 is really the Solution to the original question in Post 1, and that Post 8 is not, but (however helpful it may be) is actually an answer to the different question in Post 3.  But I'll suggest that @vishshreevT578L change the designations if that's correct, rather than do it myself.]
Kent Cooper, AIA
Message 15 of 15
patrick_35
Hi
You are right to take me back and simplify the function because I did not think
The idea is just to show the addition of two lists, regardless of the numbers. Otherwise, I agree with what was previously proposed.
