GetBoundingBox / Solar Pool Heating Coil
I had never noticed this until just now...
that vla-getboundingbox ignores the extra size of a polyline with widths > 0.
I was writing a routine to draw a coil of pipe that I will use to build a solar pool heater.
I needed to know if 100 ft. of 1 inch dia. black poly pipe would fit in a flat coil on a 4'x4' sheet of plywood with a 1/4" gap between pipes. It will work just fine, but the actual overall height and width are greater than what getboundingbox returns. Amazingly by one pipe diamter! <g>
I will face it towards the sun and pump water through it using my Little Giant cover pump so I don't have to mess with the pool filter piping. I was going to sell the pump since I have acquired an Extreme Mesh winter cover from Dover Vinyl Products in Toms River, NJ (my only client left). The cover is fantastic, but if I can heat my pool water with the pump, then I will keep it.
Does any of you wizards know a formula (and values) for computing what increase in temperature could be created?
I have attached the COIL.LSP program for your fun.
John F. Uhden
