Making range of elements of a list
rajeshpatnaik2001
rajeshpatnaik2001
If any one has a function to create range of numbers inside a list, please share with me.
Example:
(setq no_list (list 2 3 4 9 10 11 12 14 16 17 18 19 20 22))
(make_range no_list)
The output should be
("2-4" "9-12" "14" "16-20" "22")
Thanks.
rajeshpatnaik2001
I got it. Thanks!
(defun make_range (no_list* / start* new_list len cn no)
(setq start* nil)
(setq new_list (list))
(setq len (length no_list*))
(setq cn 0)
(while (< cn len)
(setq no (nth cn no_list*))
(if (= start* nil) (setq start* no))
(if (nth (+ 1 cn) no_list*)
(if (/= (+ 1 no) (nth (+ 1 cn) no_list*))
(progn
(if (/= start* no)
(setq new_list (cons (strcat (itoa start*) "-" (itoa no)) new_list))
(setq new_list (cons (itoa no) new_list))
(setq start* (nth (+ 1 cn) no_list*))
(if (/= no (nth (- cn 1) no_list*))
(if (/= start* no)
(setq cn (1+ cn))
(reverse new_list)
_gile
Just for fun.
(defun make_range (lst / toStr loop)
  (defun toStr (lst)
    (if (cdr lst)
      (strcat (itoa (last lst)) "-" (itoa (car lst)))
      (itoa (car lst))
  (defun loop (lst tmp acc)
    (cond
      ((null lst) (reverse (cons (toStr tmp) acc)))
      ((= (car lst) (1+ (car tmp))) (loop (cdr lst) (cons (car lst) tmp) acc))
      (T (loop (cdr lst) (list (car lst)) (cons (toStr tmp) acc)))
  (loop (cdr lst) (list (car lst)) nil)
Gilles Chanteau
GileCAD
GitHub
Moshe-A
@rajeshpatnaik2001 hi,
here is my 'fun' version
it also will run on unsorted or reversed list even with duplicate items.
enjoy
moshe
(defun make_range (no_list / const_subl build_range ; local functions
	                     no_list no data_range subL0 subL1)
 ; construct sublist
 (defun const_subL (no subL0)
  (if (= (- no (car subL0)) 1)
   (reverse (cons no subL0))
 ); const_subL
 ; construct result
 (defun build_range ()
  (mapcar
   '(lambda (subL)
     (cond
      ((= (length subL) 1)
       (itoa (car subL))
      ); case
      ( t
       (strcat (itoa (car subL)) "-" (itoa (last subL)))
      ); case
     ); cond
   data_range
 ); build_range
 ; here start make_range
 (setq no (apply 'min no_list))
 (setq data_range (list (list no)))
 (while (setq no_list (vl-remove no no_list))
  (setq subL0 (car data_range))
  (if (setq subL1 (const_subL no (reverse subL0)))
   (progn
    (setq data_range (vl-remove subL0 data_range))
    (setq data_range (cons subL1 data_range))
   ); progn
   (setq data_range (cons (list no) data_range))
  ); if
 ); while
 (reverse (build_range))
);  make_range
