How to get this lisp accept numbers like 0.5 15.5 etc
in this lisp any of above numbers gifs a error "Requires an integer value."
but I want the option to put in half meters of les like 0.2 ore 15.1 etc
I think the problem is in the getint but don't know what tot replace it with
(defun C:pld ()
            (setq segmentlengte (getint "\nput in distance: "))
            (setq lijn (getpoint "\nClick a line: "))
            (command "measure" lijn "b" blocknaam "y" segmentlengte)
		(setq blocknaam "rkaFF"))
(while (/= lijn nill)
            (setq lijn (getpoint "\nclick line or enter to close: "))
            (if (/= lijn nill)(command "measure" lijn "b" blocknaam "y" segmentlengte)())
   )(princ)
Accepted solutions (3)
Moshe-A
@Anonymous hi,
replace (getint) with (getreal)
_gile
Hi
Or, better, replace (getint ...) with (getdist ...) so that the user can also specify the distance by clicking two points on screen.
Gilles Chanteau
GileCAD
GitHub
ВeekeeCZ
The code, as it is, doesn't work du toe extra right parenthesis, nill should be spelled as just nil... or you could omit at all.
(defun c:PLD (/ len blk ent)
  (setq len (getdist "\nput in distance: ")
	blk "rkaFF")
  (while (setq ent (entsel "\nselect line or <close>: "))
    (command "_.measure" ent "_block" blk "_yes" len))
  (princ)
dbhunia
What I get from your code.......... You want to play with two blocks ("blocknaam" and "rkaFF") .......If so then your code should be like.....
(defun C:pld ()
        (setq segmentlengte (getdist "\nput in distance: "))
        ;(setq lijn (getpoint "\nClick a line: "))
	(setq lijn (car(entsel "\nClick a line: ")))
        (command "measure" lijn "b" "blocknaam" "y" segmentlengte)
            ;(setq lijn (getpoint "\nclick line or enter to close: "))
	    (setq lijn (car(entsel "\nclick line or enter to close: ")))
            (if (/= lijn nill)
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
	blk "rkaFF")
  (princ)
above code is what
This is what I like, even shorter code and it works perfect.
I accept the others also as solution because that was what i was asking for.
But you made the code perfect
thx
Remo
