Modify LSP to start the count from 1 to 1, 01, 001, 0001...
jtm2020hyo
Message 1 of 14
jtm2020hyo
  this rename layout from "1" to any number. adding prefix and suffix.
I need an option to start the count from  1 or  01 or  001 or 0001...
(defun c:TabInc (/ pre suf num)
 ;; Tab Increment
 ;; Rename layout tabs with number, based on location
 ;; Prefix and Suffix optional
 ;; Alan J. Thompson, 02.25.09 / 04.08.10 / 12.16.10
 (setq pre (getstring T "\nSpecify prefix <None>: "))
 (setq suf (getstring T "\nSpecify suffix <None>: "))
 (initget 6)
 (setq num (1- (cond ((getint "\nSpecify starting number <1>: "))
                     (1)
 (vlax-for x (vla-get-layouts
               (cond (*AcadDoc*)
                     ((setq *AcadDoc* (vla-get-activedocument
                                        (vlax-get-acad-object)
   (vl-catch-all-apply
     (function vla-put-name)
     (list x (strcat (rtos (getvar 'date) 2 16) "-" (itoa (vla-get-taborder x))))
 (vlax-for x (vla-get-layouts *AcadDoc*)
   (vl-catch-all-apply
     (list x (strcat pre (itoa (+ num (vla-get-taborder x))) suf))
 (princ)
Replies (13)
Message 2 of 14
Moshe-A
@jtm2020hyo hi,
if you reply to  Specify prefix with  "1 or  01 or  001 or 0001..."
and just hit ENTER to  Specify suffix , it does want you want - no?
 moshe
Message 3 of 14
dbhunia
Do you want this....
 ;; Tab Increment
 ;; Add layout tabs number, based on location
 (initget 6)
                     (1)
               (cond (*AcadDoc*)
                     ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
   (vl-catch-all-apply
     (list x (strcat pre (itoa (+ num (vla-get-taborder x))) (vla-get-Name x) suf))
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 4 of 14
jtm2020hyo
 ;; Tab Increment
 (initget 6)
                     (1)
               (cond (*AcadDoc*)
   (vl-catch-all-apply
(princ)
Thanks for your reply.
I tried to use the code but your lisp delete all my tabs  except 2
I need to generate 0 automatically, something like this:
1,2,3,4,5,6,7 ...until 9 (lisp does not should generate a "0")
01,02,03,04,05,06,07,08,09,10,11,12 ...until 99 (lisp should generate a "0")
001,002,003,004,005,006,007,008, 009, 010, 011, 012 , 013 ...until 999 (lisp should generate two "0")
(numbers "0" for each quantity) = (numbers of digits of the final tab_number) - (numbers digits current tab_umber)
example:
for a count from 1 to 999, then:
all tab-numbers with one digit should have two "0" (since 1 until 9)
all tab-numbers with two digits should have one "0" (since 10 until 99)
all tab-numbers with three digits should have zero "0" (since 100 until 999)
Message 5 of 14
dbhunia
example:
For Red mark post sample drawing (Autocad 2007 format)......
Debashis Bhunia
Message 6 of 14
dbhunia
Try this ....... (lightly tested in AutoCAD 2007).....
For.....
@jtm2020hyo wrote:
example:
(defun c:lay_num (/ lay_lst lay_lst layoutname count n)
(vl-load-com)
(setvar 'cmdecho 0)
(vlax-for layt (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
	(if (> (vla-get-TabOrder layt) 0)
	    (setq lay_lst (cons (cons (vla-get-TabOrder layt) (vla-get-Name layt)) lay_lst))
(setq lay_lst (vl-sort lay_lst '(lambda (x y) (< (car x) (car y)))))
(foreach layt lay_lst
   (setq layoutname (cons (cdr layt) layoutname))
(setq layoutname (reverse layoutname))
(setq count -1)
(repeat (setq n (length layoutname))
	(setvar 'ctab (nth (setq count (+ 1 count)) layoutname))
	(if (= (- (strlen (rtos n 2 0)) (strlen (rtos (+ 1 count) 2 0))) 2)
	   (command "layout" "R" "" (strcat "00" (rtos (+ 1 count) 2 0) (nth count layoutname)))
	(if (= (- (strlen (rtos n 2 0)) (strlen (rtos (+ 1 count) 2 0))) 1)
	   (command "layout" "R" "" (strcat "0" (rtos (+ 1 count) 2 0) (nth count layoutname)))
	(if (= (- (strlen (rtos n 2 0)) (strlen (rtos (+ 1 count) 2 0))) 0)
	   (command "layout" "R" "" (strcat (rtos (+ 1 count) 2 0) (nth count layoutname)))
(setvar 'cmdecho 1)
(princ)
Debashis Bhunia
Message 7 of 14
jtm2020hyo
your lisp code do the work but digits are adding like a prefix.
checking images we can see that code work. but I need the same options like tabinc.lsp (attached the first post)
I need rename completely and add prefix-suffix each time that code is used like lisp attached in the first post.
all non-prefix and non-suffix digits (center digits) should have the same number of digits like the highest number (the lastest). this just can be done if we add "0" to all others digits.
 PD: code is very slow because need checks each layout. I need to work like the first lisp if possible.
Message 8 of 14
dbhunia
For the Red marked......
Try this......(Roughly tested in AutoCAD 2017 & 2018)
(defun c:TabInc (/ pre suf num len)
(initget 6)
                    (1)
(setq len (strlen (itoa (length (layoutlist)))))
(vlax-for x (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
  (if (= (- len (strlen (itoa (vla-get-taborder x)))) 0) (setq pre_f pre))
  (if (= (- len (strlen (itoa (vla-get-taborder x)))) 1) (setq pre_f (strcat pre "0")))
  (if (= (- len (strlen (itoa (vla-get-taborder x)))) 2) (setq pre_f (strcat pre "00")))
  (vl-catch-all-apply
    (list x (strcat pre_f (itoa (+ num (vla-get-taborder x))) suf ))
    ;(list x (strcat pre_f (itoa (+ num (vla-get-taborder x))) (vla-get-Name x) suf ))
(princ)
I did not get the Blue marked points.......Hopefully you can manage the rest......
Debashis Bhunia
Message 9 of 14
Kent1Cooper
Does this do what you want?  It assumes you always want to start at 1 or 01 or 001 [etc.], so it doesn't include the asking for a starting number, but that could be added back in with some other alterations.  If you want the hyphens shown in your image in Message 4, as written you will need to include them in your prefix and suffix entries, but they could be built into the code instead.  Lightly tested, but at least up into 3-digit number of Layouts.
(defun c:TabIncPad (/ pad pre suf digits num)
 ;; Tab Increment, Padded
 ;; Rename layout tabs with number, based on location, padded with
 ;;   prefixed 0's so that all order components have same number of digits
 ;; Altered/expanded by Kent Cooper from code by Alan J. Thompson
  (defun pad (m / padded) ; fill out with preceding 0's as appropriate
    (setq padded (itoa m))
    (while (< (strlen padded) digits)
      (setq padded (strcat "0" padded))
    ); while
    padded ; return to main routine
  ); defun -- pad
  (setq
    digits (strlen (itoa (length (layoutlist))))
      ; how many digits in quantity of Paper-Space Layouts?
  ); setq
  (vlax-for x
    (vla-get-layouts
      (cond
        (*AcadDoc*)
    (vl-catch-all-apply
      (list x (strcat pre (pad (vla-get-taborder x)) suf))
  (princ)
Kent Cooper, AIA
Message 10 of 14
jtm2020hyo
@dbhunia
you are the best in whole forums.autodesk.com
I want to be like you a day.
Message 11 of 14
jtm2020hyo
@Kent1Cooper
thanks for your code. help me a lot.
Message 12 of 14
jtm2020hyo
hello.
please, add an option to start numbering since a selected number.
like first attached LISP. I need it. please. thanks
Message 13 of 14
dbhunia
I think the little modification(Blue) on @Kent1Cooper code will fulfill your requirements.......try this....
    ); while
  ); defun -- pad
  (setq
                  (1)
  ); setq
  (vlax-for x
    (vla-get-layouts
      (cond
        (*AcadDoc*)
    (vl-catch-all-apply
      (list x (strcat pre (pad (+ num (vla-get-taborder x))) suf))
  (princ)
Debashis Bhunia
Message 14 of 14
jtm2020hyo
    ); while
  ); defun -- pad
  (setq
                  (1)
  ); setq
  (vlax-for x
    (vla-get-layouts
      (cond
        (*AcadDoc*)
    (vl-catch-all-apply
  (princ)
this code is simply perfect.
thanks a lot. @dbhunia @Kent1Cooper @Moshe-A
