Making a table from dynamic blocks in a drawing, referencing visibility state and one particular attribute
wsonnek
Message 1 of 59
wsonnek
I'm working on yet another lisp (y'all got me hooked, I swear) that's attempting to take all the blocks in a drawing and make a table with them. I started with the two lisps linked below - the first one was almost exactly what I wanted for a table, but didn't handle the dynamic blocks well. The second counted dynamic blocks, but didn't have a way to make a good table. I tried to combine them and kinda wrecked it. Either way, neither of them allowed for counting based on the SIZE attribute, which is kind of important.
Basically, I have a ton of different 2D valves in a drawing. The valves are dynamic so I can switch between types (ball, globe, gate, etc) in-place without messing with the size. The size is an attribute (2", 3", 1/2", etc) for the block. There are a few stand-alone valves that I also need to count. I want the table to be "Block Name" "Block Type" (that's the visibility state) "Block Size" (attribute). That way I can quickly tally up what I've got in the drawing  and figure out how many 2" ball valves I need, 3" butterfly valves, etc.
Thoughts?
https://www.lee-mac.com/dynamicblockcounter.html
https://www.lee-mac.com/blockcounter.html
Replies (58)
Message 41 of 59
cadffm
Edit what Sea-Haven suggest,
add another line, marked here
And it will count Your blocks without attribut and visibility informations.
But you talked about a Valve table, your sample block is not a Valve, so why should this Tool for these blocks too?
Thumb up to start wirh Lisp books and tutorials, in few years you are able to edit such code by your own
and later you will write them from scratch.
Sebastian
Message 42 of 59
wsonnek
I have some 3D valves, I'm just not comfortable sharing those online so I shared the Tees instead. The 3D valves don't have attributes but some are dynamic. I thought by taking this that I'd be able to count both the regular and dynamic blocks and just leave the visibility states and size attribute blank if they don't exist. Does that kinda make sense? Maybe I'm over-complicating this.
Message 43 of 59
cadffm
Okay, that will explain it.
Yes and the solution is explained above.
Create a copy of your .lsp file,
edit waht Sea-Heaven wrote
add what I showed above (yellow marked part) wrote
save .lsp, APPLOAD this .lsp, test it.
Sebastian
Message 44 of 59
wsonnek
I deleted the 66.1, added the new line, and tried to import, but I got a syntax error. I think there needs to be another argument for ssget?
; 	'add_valves_table' custom command for ws
;	komondormrex, feb, 2025
;	totally free of lm
(defun get_text_length (text_string text_size / dtext_box_list)
	(if (= "" text_string)
		0
		(progn
			(setq dtext_box_list (textbox (list '(0 . "TEXT") (cons 1 text_string) (cons 7 (getvar 'textstyle)) (cons 40 text_size))))
			(+ (* 2 text_size) (- (caadr dtext_box_list) (caar dtext_box_list)))
(defun add_table_from_list (table_list table_headers / table_text_size table_object row_index column_index columns_widths)
	(if (null table_text_size_saved) (if (zerop (getvar 'measurement)) (setq table_text_size_saved (/ 3.5 25.4)) (setq table_text_size_saved 3.5)))
  	(if (null (setq table_text_size (getreal (strcat "\nEnter table data text size <" (rtos table_text_size_saved) ">: "))))
  		(setq table_text_size table_text_size_saved)
  		(setq table_text_size_saved table_text_size)
  	(setq table_object (vla-addtable (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
  										 (vlax-3d-point (getpoint "\nSet table insertion point (Left Upper Corner): "))
  										 (+ 2 (length table_list)) 																					;	number of rows
  										 (length table_headers) 																					;	number of columns
  										 (* 2.5 table_text_size)             																		;	row height
  										 1
  		   row_index -1
  		   column_index -1
	(vla-deleterows table_object 0 1)
	(vla-put-regeneratetablesuppressed table_object :vlax-true)
	(mapcar '(lambda (list_member) (vl-catch-all-apply 'vla-setcolumnwidth (list table_object (car list_member) (cadr list_member))))
			 (mapcar '(lambda (column_width) (list (setq column_index (1+ column_index)) column_width))
					  (setq columns_widths (mapcar '(lambda (string) (get_text_length string table_text_size)) table_headers))					;	width of column 0 thru last
	(setq table_list (cons table_headers (mapcar '(lambda (row) (append (car row) (list (itoa (cdr row))))) table_list)))
	(foreach row table_list
		(setq column_index -1
			  row_index (1+ row_index)
			  columns_widths (mapcar 'max columns_widths (mapcar '(lambda (string) (get_text_length string table_text_size)) row))
		(foreach column row
			(vla-settext table_object row_index (setq column_index (1+ column_index)) (nth column_index row))
			(if (and (> row_index 0) (zerop column_index))
				(vla-setcellalignment table_object row_index column_index acmiddleleft)
				(vla-setcellalignment table_object row_index column_index acmiddlecenter)
			(vla-setcelltextheight table_object row_index column_index table_text_size)
			(vla-setrowheight table_object row_index (* 2.5 table_text_size))
	(setq column_index -1)
					  columns_widths
	(vla-put-regeneratetablesuppressed table_object :vlax-false)
(defun parse_list (_list / unique_list old_member)
	(foreach _member _list (if (not (member _member unique_list)) (setq unique_list (append unique_list (list _member)))))
	(setq unique_list (mapcar '(lambda (_member) (cons _member 0)) unique_list))
		(if (setq old_member (assoc _member unique_list))
				(setq unique_list (subst (cons (car old_member) (1+ (cdr old_member))) old_member unique_list))
(defun get_the_valve (/ insert_sset valve_list size_attribute vis_property vis_property_value)
	(prompt "\nPick the valves to be listed in a table...")
	(if (setq insert_sset (ssget '((0 . "insert"))))  selects all attibuted inserts
		(setq valve_list (parse_list
				   			(vl-remove nil
			       				(mapcar '(lambda (insert) (if (and (vl-some '(lambda (attribute) (= "SIZE" (vla-get-tagstring (setq size_attribute attribute))))
				   				               			    	       	 	 (vlax-invoke insert 'getattributes)
				   				           			           	   )	;checks if there is "SIZE" tagged attribute in insert
				   					                               (if (vl-some '(lambda (dyn_property) (= "Visibility1" (vla-get-propertyname (setq vis_property dyn_property))))
				   									    	     	 			 (vlax-invoke insert 'getdynamicblockproperties)
				   									       			   )	;checks if there is "Visibility1" dynamic property in insert
				   									       			   (setq vis_property_value (vlax-get vis_property 'value))
				   									       			   (setq vis_property_value "")
				   							      	      	  (list (vla-get-effectivename insert) vis_property_value (vla-get-textstring size_attribute))
				   							      	      	  (list (vla-get-effectivename insert) "-" "-")
				   					    (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex insert_sset))))
(defun c:add_valves_table (/ valves_list)
	(if (setq valves_list (get_the_valves))
		(add_table_from_list valves_list '("Block Name" "Block Type" "Size" "Count"))
	(princ)
Message 45 of 59
komondormrex
Message 46 of 59
wsonnek
Message 47 of 59
cadffm
1. you merged parts from different postings!
2. Your error don't match your posted code
Here we go
I took YOUR posted code
and added the ; as komondormex said
and changed the functionname (your function named like the old version, i didn't checked the reason and the content of the old vs new)
if get_the_valve is defined, you can't start get_the_valveS
if get_the_valveS is defined, you can't start get_the_valve
		0
		(progn
  										 1
  		   row_index -1
  		   column_index -1
		(foreach column row
					  columns_widths
	(if (setq insert_sset (ssget '((0 . "insert")))) ; selects all attibuted inserts
				   			(vl-remove nil
	(if (setq valves_list (get_the_valve))
	(princ)
Sebastian
Message 48 of 59
Sea-Haven
As you mentioned if your starting to look at more block names in particular dynamic blocks, you may need a cond that looks at 'effectivename' and matches then say look for a tagname or a dynamic property name.
Re blank entries just a comment I have a sort & count blocks with attributes the blocks can have no attributes or more than the 5 I look at as part of the count match, so for a non its result is (Blkname "-" "-" "-" "-" "-") I pad the resulting list to make all sub lists the same length.
Message 49 of 59
wsonnek
BEAUTIFUL!!!!!! This is exactly what I needed. Thank you all so much!!!!!
Message 50 of 59
komondormrex
that is the most funny thing to make Seb the solver imo 🤣🤣🤣🤣🤣 cause it totally is my code)))
Message 51 of 59
wsonnek
Whoops, sorry, I didn't see the name! I think I can move it if you repost?
Message 52 of 59
cadffm
This seems to be a trend at the moment
Sebastian
Message 53 of 59
komondormrex
vulturing, to be exact?
Message 54 of 59
cadffm
I think you can mark multiple replies and perhaps, you can remove them too - but I am not sure.
@komondormrex
Oh, questions come up and after the first answer, 3-4 other users come along and write exactly the same thing.
It's not the first person who gets tagged, often not the person with the best explanation, but simply the last poster.
All of this is normal, but in the last few weeks I've noticed it again.
Sebastian
Message 55 of 59
komondormrex
do you really believe you have solved this kb request, just curious?
Message 56 of 59
cadffm
Hi, komondormrex, I think I can tell from your question that you seem to have completely misunderstood something.
Please excuse me, this is probably due to my very limited ability with the English language.
I helped the OP with a modification to extend the code and a second time with using the forum.
No, I don't think I answered the original question of this thread, but I have no idea why you're asking.
Sebastian
Message 57 of 59
wsonnek
The only reason I marked the solution above as accepted was that it had the whole working code. I apologize, I didn't check to see who did the final version. @komondormrex if you repost with the whole code, I can credit you for it. You did 95% of it and I really appreciate it. @cadffm thank you for your help as well!
Message 58 of 59
komondormrex
@wsonnek
you must have been kidding) it's 99.9%. and if you look carefully at the subject of your post it will totally clear the case. but whatever)
@cadffm
you and people like you are the main reason to hide the original text code behind compiling, otherwise there will be always mess like that)
Message 59 of 59
wsonnek
I apologize and I would like to credit you with the solution. If you can repost it I will. I would like to mark the solution in one place so anyone who's looking for it can easily find it.
