Macro that runs automatically when I close a file
I want to prepare a macro that runs automatically when I close a file. Is this possible?
Thank you for your answers
Kent1Cooper
Probably not with a command macro.  If you are using a full AutoCAD program [not LT], it should not be difficult to make a new definition of the CLOSE command, including Undefining the original.  The new version could do whatever you want before calling for a native Close command at the end.
But I think this kind of thing has come up before [I'll let you Search], and a difficulty may be that you would need to always do it using the new command definition -- it may not work when you use the X-at-upper-right way of Closing.
Kent Cooper, AIA
