Macro - Make Layer
Macro - Make Layer
Macro - Make Layer
Within a Macro. how can I get the user to type a layer name; and then carry out the rest of the sequence of commands?
^C^C_-LA;c;8;rev*;;M;/;C;4;;;
jdiala
use backslash, instead of a forward slash then continue your command
^C^C_-LA;c;8;rev*;M;\;
Kent1Cooper
... and note that [as @jdiala wrote it out] there should be only one semicolon between the rev* and the M.  With two of them as in your original, the Layer command will be ended, and the M will be taken as a new command name [the command alias for Move, if you haven't changed that].
Kent Cooper, AIA
