Macro-insert block then copy last object
I use blocks to label esmt widths fo momen plats and have been experimenting with creating a macro that would do this a lot easier. This is what i have so far, but its making me still click the block and right click to start the copy command. Is there any way to instert the L into the Diesel copy command so it will automaticly grab the block last created?
thanks for the help!
^C^C_insert;E10;R;\\\;1;$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy)
hmsilva
Hello scottysimonett and welcome to the Autodesk Community!
try for single copy
^C^C_insert;E10;R;\\\;_.Copy;_L;;@;
or for multiple copy
^C^C_insert;E10;R;\\\;_.Copy;_L;;_M;@;
Hope this helps,
Henrique
try for single copy
Hope this helps,
Henrique
Thanks for the help Henrique!
This just needed a tiny adjustment adding the scale modifier but it worked like a charm after that!
^C^C_insert;E10;R;\\\;1;_.Copy;_L;;_M;@;
One last thing, after playing around with it for a bit I am curious if the macro could while i was in the multiple copy command to be able to rotate the block and keep copying the multiples. I would use this macro 30 to 40 times a week and that would save a lot of time.
Thanks again!
Played with it a bit more and found the MOCORO command, I am not too familiar with what the (GETVAR 'LASTPOINT) is using to get its base point but is seem to work in test runs. What do you think? It seems to work like your macro but it gives me the option of getting into a rotate command if I need to.
^C^C_insert;E10;R;\\\;1;_MOCORO;_L;;(GETVAR 'LASTPOINT);C;
Again, thanks in advance.
hmsilva
You're welcome, scottysimonett.
the (GETVAR 'LASTPOINT) , from the help files:
Stores the last point specified, expressed as UCS coordinates for the current space.
You can reference the last point by entering the at symbol (@) at a point prompt.
therefore@, (GETVAR 'LASTPOINT) or @ should return the last point specified...
Henrique
