Breaking select lines
Does anybody have a lisp routine that will allow a user to select a line, whether vertical or horizontal as a cutting line, then be able to select the lines running through it you want to break at a set distance?
I would like to select a horizontal line, for instance, then choose any number of vertical lines that cross it and have those lines "break" where they intersect the horizontal line.
I've seen a routine that seems to work, but it will break "ALL" the lines that cross it.  I want to be able to select just the ones I want to break.  Because I do have times that I want some interesecting lines kept unbroken.
I'm far too novice at lisp to get anywhere with this.  Any help would be appreciated.
Cheers!
Doug
Ajilal.Vijayan
Try this lisp, BREAKOBJECT command in this lisp seems to suit your requirements.
http://www.theswamp.org/index.php?topic=10370.0
Perfect! Exactly what I was looking for. Thank-you very much!
Doug
Ajilal.Vijayan
Welcome Doug.
Glad that helped you.
