Creating a selection set from 3 decimal place coordinates?
camedge
camedge
I'm taking a set of coordinates from a .csv and then trying to create a selection set of lines that end at those coordinates.
Assuming these are the coordinates-
(setq x "321535.509" y "5807325.787" z "0.000")
Creating a selection set like this-
(setq coord (list (atof x) (atof y) (atof z)))
(setq 10ss (ssget "x" (list '(0 . "LINE") '(-4 . "=,=,*") (cons 11 coord) )))
I believe the problem I'm having is that, as I've read elsewhere "that the real precision (accuracy) of real numbers in AutoLISP is 16 digits". Therefore the coordinates that I have are only to 3 decimal places whereas in cad the lines (if I turn up the precision I can see) go to that much more detailed precision therefore my selection set is coming up with nil.
Does anyone have any suggestions of how I might be able to create that selection set with my 3 decimal place coordinates?
hmsilva
Hello camedge and welcome to the Autodesk Community!
_$ (setq x "321535.509" y "5807325.787" z "0.000")
"0.000"
_$ (setq coord (list (atof x) (atof y) (atof z)))
(321536.0 5.80733e+006 0.0)
_$ (setq 10ss (ssget "x" (list '(0 . "LINE") '(-4 . "=,=,*") (cons 11 coord) )))
<Selection set: 2a5c>
_$ (mapcar 'rtos coord)
("321535.509" "5807325.787" "0.000")
_$
AutoCAD displays the REAL numbers rounded, but the real value is unchanged.
Probably while creating the .csv file, the REAL numbers were rounded...
Try something like this:
      fuzz  0.001
(setq 10ss (ssget "_X"
                  (list (cons 0 "LINE")
                        (cons -4 "<and")
                        (cons -4 ">,>,*")
                        (cons 11 (list (- (car coord) fuzz) (- (cadr coord) fuzz) (caddr coord)))
                        (cons -4 "<,<,*")
                        (cons 11 (list (+ (car coord) fuzz) (+ (cadr coord) fuzz) (caddr coord)))
                        (cons -4 "and>")
Hope this helps,
Henrique
camedge
Thanks Henrique,
I can see how that would work. I'll give it a try tomorrow. (Although I'll also try to get better output from the surveyors, but they don't seem the most flexible bunch!)
Cheers
Cameron
hmsilva
You're welcome, Cameron!
Glad I could help
Henrique
