LSP Command to change User Section Layers Easily
Hi Everyone,
I have a copied LSP routine from another forum from a few years ago, and I thought I had added everything needed for Advance Steel. I get to the point where I need to select the layer but it wont and states invalid option keyword.
(defun c:USc ( / layers layer ss )
  (setq layers '(
"Hype_Frame"
"Hype_TypeName"
"Hype_SectionName"
"Hype_OuterSection"
"Hype_ExactOuterSection"
"Hype_InnerSection"
"Hype_ExactInnerSection")
  (initget 1 "Hype_Frame Hype_TypeName Hype_SectionName Hype_OuterSection Hype_ExactOuterSection Hype_InnerSection Hype_ExactInnerSection")
  (setq layer (getkword "\nChoose Target Layer [A_Hype_Frame/B_Hype_TypeName/C_Hype_SectionName/D_Hype_OuterSection/E_Hype_ExactOuterSection/F_Hype_InnerSection/G_Hype_ExactInnerSection] : "))
  (setq layer (car (member layer layers)))
  (if (setq ss (ssget "_:L"))
    (command "_.chprop" ss "" "_LA" layer ""))
  (princ))
Above is the routine, and any help would be great highlighting the errors inside.
Thank you.
pbejse
@Anonymous wrote:
Hi Everyone,
Thank you.
Could be written this way
(setq layers '(
		("A" "Hype_Frame")
		("B"" Hype_TypeName")
		("C" "Hype_SectionName")
		("D" "Hype_OuterSection")
		("E" "Hype_ExactOuterSection")
		("F" "Hype_InnerSection")
		("G" "Hype_ExactInnerSection")
(initget 1 "A B C D E F G")
(setq layer (getkword "\nChoose Target Layer [A Hype_Frame/B Hype_TypeName/C Hype_SectionName/D Hype_OuterSection/E Hype_ExactOuterSection/F Hype_InnerSection/G Hype_ExactInnerSection] : "))
(setq layer (cadr (assoc layer layers)))
You can also use numbers.
(setq layers '(
	"Hype_Frame"
	"Hype_TypeName"
	"Hype_SectionName"
	"Hype_OuterSection"
	"Hype_InnerSection"
(initget 1 "1 2 3 4 5 6 7")
(setq layer (getkword "\nChoose Target Layer [1 Hype_Frame/2 Hype_TypeName/3 Hype_SectionName/4 Hype_OuterSection/5 Hype_ExactOuterSection/6 Hype_InnerSection/7 Hype_ExactInnerSection] : "))
(setq layer (nth (1- (atoi layer)) layers))
HTH
Sea-Haven
Another using dcl
(if (not AH:Butts)(load "Multi radio buttons.lsp"))
(if (not but)(setq but 1))
(setq layers '("Please choose"
	"Hype_Frame"
	"Hype_TypeName"
	"Hype_SectionName"
	"Hype_OuterSection"
	"Hype_InnerSection"
(setq ans (ah:butts but "V" layers))
