Create report in Autolisp
avinash00002002
avinash00002002
Hi
I want to create Data report like (Dataextraction command (page 5 or 😎 in AutoLISP.
Avinash
braudpat
Hello
When I see your screen capture, it seems to be a report on Blocks only !?
So I have a beautiful Lisp routine "ListBlock" from Gilles (gile) which generates a quantity report on Blocks ...
"ListBlock" has only (for me) a small default : it doesn't analyse Blocks into associative arrays !
( Associative arrays must be exploded )
So maybe if somebody can improve "ListBlock" , it could be useful !?
A similar routine from Lee-Mac :
http://www.lee-mac.com/blockcounter.html
An other one a little bit different :
http://www.lee-mac.com/dynamicblockcounter.html
But maybe you need an other / better routine, if you need the display of attributes !?
http://www.lee-mac.com/macatt.html
Thanks in advance, The Health, Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
braudpat
Hello
An other french routine "LSTATT" (from Patrick_35) which displays results on text / command screen or into a file ...
Patrice BRAUD
avinash00002002
Hi
Thanks for your prompt reply, I want report on screen like dataextraction command is it possible?
braudpat
Hello
The "LSTATT" routine displays results on text / command screen or into a file ...
Patrice BRAUD
john.uhden
What's wrong with that image you posted?  If that's the data you want, then just Snippit and paste into a Word doc.
I currently have had a problem at work where a fellow worker downloaded what he thought to be a newer municipal detail than what we had had.  But he gave it a different name and deleted the older one which my drawing had referenced.  The killer is that the old and new were exactly the same.  Unless you paste them "special" AutoCAD treats images as references, whereas Word incorporates them right into the file.
We're going to have a big pow wow on Monday wherein I think I will be tempted to customize his face.  He's the self-appointed IT guy who knows less about AutoCAD than our survey draftsman, who by the way would be a much better IT guy.
John F. Uhden
Sea-Haven
To show on screen will not get nice box output will be lines of text, could do auto open excel and display more complicated.
For this type of question your display request is to vauge there are a massive amount of get block details and how deep they go, for me I sort down to 5 levels of attributes way better than Dataextracion.
Lee-mac block count another good one.
