Loop through all sample lines?
Im looking for a way to loop through all sample lines. Im using this code for the surfaces but changing the 'Surfaces to 'SampleLines, 'Alignments, etc doesn't seem to work. Someone has any idea how I can loop through all sample lines?
;create file and init the loop
(setq surfcoll (vlax-get c3ddoc 'Surfaces)
	 surfctr (vlax-get surfcoll 'Count)
	 ctr 0
(while (< ctr surfctr)
;etc
Thanks!
Niels
Ranjit_Singh
Not sure what the end goal is, so I am just calling vlax-dump-object for each sample line. You can change the code as needed. Minimal testing.
(defun c:somefunc  (/ alignobj)
 (vlax-for i  (vlax-get (vlax-ename->vla-object (car (entsel "\nSelect Alignment: "))) 'samplelinegroups)
  (vlax-for j (vlax-get i 'samplelines) (vlax-dump-object j))))
