looking for guidance!
nicholas.carterB4EKC
Message 1 of 22
Hey all,
I am looking for guidance / assistance on how to best approach make a script file of some sort to make my current work more automated.  I do not know if it is possible?  I am looking for a way to make these electrical line tags match what address block and terminal number is displayed on the left hand side.  When the address and terminations blocks change I have to go through each tag on the right hand side and type in the values to match.. which is very time consuming.  I would like for them to just automatically update.  Please see attached image for reference.
Thanks in advance!
Replies (21)
Message 21 of 22
Gotcha.  So you know Fields command will be the end all be all for my problem??
Message 22 of 22
cadffm
For your  given sample, yes. For ALL your problems? No
With simple Text, as you worked before, you can use FIND as well.
Mark all Text, use Find to replace the part in question. No need to change 5 times by click on 5 text elements.
But using fields are more smart, or?
Sebastian
