Look for help adding code to explode inserted block...
Good afternoon,
 I have a lisp that I use to insert a specific block into a drawing:
(defun c:Insds ()
 (setq osnapold (getvar "osmode"))
 (setq dimsc (getvar "dimscale"))
 (setq Inspt (getpoint "\nSelect Block insertion point: "))
 (command "-insert" "drawing scales" Inspt dimsc "" "" )
 (setvar "osmode" osnapold)
I greatly appreciate the community and your help.
Regards.
hmsilva
Hi cadcre8er,
in your code you are setting the 'osnapold' variable with the "osmode" value, do you need to modify "osmode" in your code?
(defun c:Insds ( / dimsc Inspt osnapold)
  (setq osnapold (getvar "osmode"));<<< ????
  (if (setq Inspt (getpoint "\nSelect Block insertion point: "))
    (command "-insert" "drawing scales" "_NON" Inspt dimsc "" ""
             "_.explode" (entlast)
  (setvar "osmode" osnapold);<<< ????
  (princ)
Hope this helps,
Henrique
