LISP edit DWG Statistics?
mid-awe
mid-awe
Hi all,
I did some searching only to find that the code at the link below does write the value to the drawing, but does not display the value as expected. Can anyone help correct the issue?
drawing properties, statistics, revision number
Thank you in advance for any help/ advice.
hmsilva
Hi mid-awe,
try
(vla-put-revisionnumber (vla-get-summaryinfo (vla-get-activedocument (vlax-get-acad-object))) "001")
Hope this helps,
Henrique
mid-awe
Wow, thank you Henrique. Works perfectly.
hmsilva
You're welcome, mid-awe!
Glad I could help
Henrique
