How to add Geometric Center Osnap Temporary Override Key.
Shneuph
Shneuph
I believe the Geometric Center object snap is new to AutoCAD 2016.  I think it's a useful addition as I often like to place text in the center of a rectangular polyline etc.
I also use temporary right click menu osnap overrides often for object snaps that I don't keep running all the time.  I use osmode 4199 in case anyone cares.  Consequently, I have learned the shortcut keys in this menu for osnaps that I often use "G" for tangent "N" for none etc. (full list below).  However, I couldn't figure out which key to hit in 2016 to run the Geometric Center snap.  That's because by default there is none.  Below is a list of keys that you can use to select items in the Object Snap Cursor Menu:
F - From
T - Mid Between 2 points
N - Endpoint
M - midpoint
I - intersection
A - apparent intersection
X - extension
C - center
  - Geometric center
Q - quadrant
G - tangent
P - perpendicular
L - parallel
D - node
S - insert
R - nearest
N - none
O - osnap settings
You may guess that you can spell out you can spell out "Geometric Center" using letters which are already assigned to shortcut keys.  You'd be right, I verified this.  So, the fix...
Type CUI to open the Custom User Interface dialog.  (see attached image).  Select the "Main Customization File" from the pulldown and find "Shortcut Menus>Object Snap Cursor Menu"  Inside you will find "Geometric Center", click on it.  Now you have these letters leftover to choose from (at least I did)
BHJKUVWYZ
I selected 'V' because it's easy to hit.  Now just rename the menu command with the letter you chose.  e.g. I used "Geometric Center &V" (again see attached image) and include the "&" symbol before your letter.  Hit OK to save changes to yoru CUI and the next time you use the right-click osnap override menu you should be able to hit your letter to use the Geometric Center snap.
I hope this is helpful to someone and that I am not breaking some sort of ettiquette by not actually asking a question.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
carlos_m_gil_p
Good day.
Thanks for the info.
Is there any way to incorporate pressing shift and (any key)
(Temporary Override Keys)
Excuse my English, I only speak Spanish.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
Shneuph
Sure you can. In the CUI editor under the "Main" customization file, duplicate one of the other osnap override keys by right-clicking (See attached images), rename the new shortcut key command and put 1024 in place of the original osmode number.  Assign a shortcut key that isn't already used and you should be good to go.
carlos_m_gil_p
Hello Brother, how are you.
Thanks for your help.
It worked perfectly.
A million thanks.
AutoCAD 2026
Shneuph
You're welcome.  I'm glad it helped someone!
carlos_m_gil_p
Hello Brother how are you.
I wanted to ask you another question.
How you could accomplish do what was done with GeomCenter Temp Override.
But in this case to modify Mid Between 2 Points.
Excuse my English.
Thank you.
AutoCAD 2026
