Look for and CREATE OR SET FOLDER for quick plot routine
DC-MWA
DC-MWA
I have a program for fast plots to pdf. It makes the pdf's using the drawing name and puts them in the current drawing folder.
I need have the program look for a folder named "QUICK PLOTS" in the current drawing folder, if it finds it, put the pdf file in that folder. If the folder does not exist, make the folder and then put the pdf in the new folder.
Thank you in advance for any assistance.
Moshe-A
@DC-MWA
i see that you are very active and that good Smiley LOL
to achieve what you want, look at these functions:
(vl-directory-files)
(vl-mkdir)
DC-MWA
With my limited knowledge I think I could use vl-mkdir to make the directory, but to have it check to see if the directory exists, make it or set it and then incorporate it into the program....
Way above my head.
john.uhden
(and
(= (getvar "dwgtitled") 1) (vl-load-com)
(setq *doc* (vla-get-activedocument (vlax-get-acad-object))) (setq path (vl-filename-directory (vlax-get *doc* 'fullname))) (or (vl-file-directory-p (strcat path "\\Quick Plots")) (vl-mkdir (strcat path "\\Quick Plots")) ) )
John F. Uhden
dbhunia
Check the attached Code for one pattern "P42".......(it has been tested in Autocad 2017).......
For your information the below line may vary according to Autocad Version.....
(command "-plot" "yes" "" "DWG TO PDF.PC3" "ARCH expand E1 (30.00 x 42.00 Inches)" "Inches" "Landscape" "n" "extents" "1:1" ".113427,.113168" "y" "monochrome.ctb" "n" "A" file "n" "Y")
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
maratovich
Attach an example of your dwg file
I need an example of your title block.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
DC-MWA
thank you very much!!!
