Set Display Configuration to "Reflected" using autolisp or command line
DC-MWA
Message 1 of 11
DC-MWA
I need to set the display configuration to reflected as part of a lisp I'm working on. Is this possible?
the command is "AecDisplayManagerConfigsSelection" I can enter "R" at the command line and make it work, but it will not work in autolisp program. Any ideas?
Replies (10)
Message 2 of 11
Moshe-A
@DC-MWA hi,
try this:
(Command "-AecDisplayConfigSetCurrent" "yourDisplayCfg")
moshe
Message 3 of 11
DC-MWA
Thats the first thing I tried.... No luck.
Message 4 of 11
DC-MWA
I have attached the lisp file with comments to what I'm trying to achieve within.
Message 5 of 11
Moshe-A
@DC-MWA
look again and this time more closely
the command should be prefixed by '-' char
Message 6 of 11
DC-MWA
Tried it. Didn't work.
Command: (command "-AecDisplayManagerConfigsSelection" "Reflected")
-AecDisplayManagerConfigsSelection Unknown command "-AECDISPLAYMANAGERCONFIGSSELECTION". Press F1 for help.
Command: Reflected Unknown command "REFLECTED". Press F1 for help.
Command: nil
If I enter just the command (command "AECDISPLAYMANAGERCONFIGSSELECTION"), it works but pops up menu for user to select from. I have attached an image showing result... If I do it from the command line, I can enter the first letter "R" and it selects reflected without clicking on menu. Can't do it from lisp. Tried filedia 0. Tried -xx.
Message 7 of 11
Moshe-A
then maybe this command is not on AutoCAD Vanila - do you have AutoCAD Architecture?
Message 8 of 11
DC-MWA
Yes
Message 9 of 11
DC-MWA
So is that it? Is it not possible?
Message 10 of 11
Moshe-A
sorry do not know i do not familiar with architecture
Message 11 of 11
cadffm
Try it again, that should work 100%
(Command "_.-AecDisplayConfigSetCurrent" "STANDARD")
Sebastian
