loading multiple blocks
ctnycc
ctnycc
Good day,
I was wondering if anyone has a routine that will load multiple blocks into a drawing with each one having its own preset location point in the drawing.  I have a folder with the blocks in and want to be able to select them all and have them inserted into the drawing in one go.
Any hope for this?
Thanks in advance
Regards
Colin
ВeekeeCZ
@ctnycc wrote:
Good day,
... with each one having its own preset location point in the drawing...
Regards
What does it mean? Where you have specified these points? Do you have a separete txt/csv/xls list? Or would you specify those manually?
ctnycc
Each block is a map grid and when inserted it is correctly positions in the grid.
ВeekeeCZ
Insert those as xrefs and then bind all of them?
