Menu file in autocad 2015
ganderson
ganderson
   I'd like to add a customized insert block command to autocad 2015. Can someone tell me where the mnu file is or should I be modifying another file?
                          Giovonnae
ВeekeeCZ
You have the lisp or macro?
There is CUIX file in AutoCAD 2015, but any change you need to do manually within _CUI command anyway.
ganderson
Thanks for your reply, but I don't know what you mean when you ask if I have the LISP or Macro. I'd like to make the insert panel in AutoCad 2015 look more like the Hatch panel. That is have several different panels of things to insert. In older versions of AutoCad there was a menu file that you could look at and modify, but maybe it's not there anymore? is there a way to customize commands?
                          ~Giovonnae
ВeekeeCZ
Sorry, I don't follow you. But anyway, first type _CUI command in AutoCAD - this is the place, where you should start. If you need some help, then see some videos on youtube.
Then..
- what hatch panel do you mean? post some screenshot.
- what do you want to insert, how? Describe, show picture... I don't know.. 🙂
- did you tried ToolPalletes? CTRL+3. Very suitable for this stuff and very easy to work with and adjust. (also see youtube)
