LOAD error
LOAD error
Lineabove
LOAD error
Lineabove
Hello Forum,
If I load the attached file I will receive an:
Command: _appload LOAD on Error.lsp successfully loaded.
Command: C:0CURRENT
error: bad character read (octal): 0
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
What I do not understand is that if I load all the files individually, there is no error.
I am stumped.
All suggestions are appreciated.
Mel
Ranjit_Singh
Looks like you are calling the routine as C:0Current. I believe it should be 0Current without the c:
Lineabove
Hi Ranjit,
Thank for your reply.
The actual line is:
(princ (load "C:/Program Files/Architecture Custom/Acad Startup Suite/0Current.lsp" "\n0Current.lsp not loaded"))
I verified that the Lisp is named 0Current.lsp
The lsp file is:
(defun C:0Current ()
(command "_.layer" "_Thaw" "0" "_Make" "0" "_Color" "White" "" "_Ltype" "Continuous" "" "_LWeight" "0" "" "_PStyle" "0" "" "")
    (princ)
The C: is so I may call as an AutoCAD command.
Ranjit_Singh
Yes the C: means you can invoke it at command prompt. You do not need to type c: when invoking the function. You have to type it when your function has arguments, but then you are really calling it as a lisp statement such as (c:somefunc arg1 arg2 ...); and not as a native autoCAD command.
However you function does not take any argument and so should be called as native autoCAD command, that is without the c:
john.uhden
What @Ranjit_Singh said is dead on (which is pretty much true of whatever he says).
You could save yourself a little typing by adding...
(defun c:0C ()(c:0Current))
That way, at the command prompt you could enter either "0Current" or just "0C" (both without including the quotes).
John F. Uhden
