Correct syntax of SSGET with :E
tcorey
Mentor Mentor
tcorey
I am attempting to use SSGET's "_:E" function, but I have been unable to find an example.
If I use (setq obs (ssget "_:E")), the user is asked to pick a point. It correctly finds all objects touched by the pickbox. Sweet, but I want to feed a point variable to the function, not make the user pick.
If I use (setq obs (ssget "_:E pt)), I get error: bad point argument
and the same if I use (setq obs (ssget pt "_:E"))
Thanks, if you can help.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Ranjit_Singh
You can simply pass a point in ssget as
(ssget pt1); where pt1 is a list of x y and z
but it will only select a single entity that is on top of other entities at that point. To select multiple you need to call other methods. Example with fence
(ssget "_f" (list (mapcar '- pt1 '(0.01 0 0)) (mapcar '+ pt1 '(0.01 0 0))))
tcorey
Thanks for your reply, but the :E switch is meant to find all objects within the pickbox. From the Help:
:E Everything within the cursor's object selection pickbox.
Here's a link if you want to see the entire article:
http://docs.autodesk.com/ACD/2011/ENU/filesALR/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-693e.htm
Tim Corey
Redding, CA
Ranjit_Singh
You are correct. But as far as I know you cannot pass a point argument to E: ssget method. The method that I pointed out with point is not the same as E: and isn't documented. Never the less, that is the only way, as far as I know where you can pass a single point as an argument.
You will have to use fence or cp, if you wish to select all objects at a point. I would be very eager to find out if there is anyother ssget way to pass a point argument and select multiple objects that cross at a point.
tcorey
Thanks for the clarification. It appears the :E function is only for use when there will be user input, I guess. That's a bummer, but c'est la vie.
I am going to follow your advice and use crossing.
Tim Corey
Redding, CA
Ranjit_Singh
You are welcome.
