list inside list
list inside list
nitin.rathod3CW9S
list inside list
nitin.rathod3CW9S
I was wondering if you can help me with the list updating issue I have.
Here is the issue, I have a list of four values that look like below.
[0] ("list1" ( "1"  "2" ))
[1] ("list2" ( "11"  "12" ))
[2] ("list3" ( "21"  "22" ))
[3] ("list4" ( "31"  "32" ))
I want to add the value "13" to "List2" so that the output looks like the list below.
[1] ("list2" ( "11"  "12" "13"))
If the input is to add "41" to "list5" then the output should look like the list below.
[4] ("list5" ( "41" ))
Let me know if you can help me with a sample code to do something like this.
pbejse
Sample code
(setq MainList
       '(("list1" ("1" "2"))
	 ("list2" ("11" "12"))
	 ("list3" ("21" "22"))
	 ("list4" ("31" "32"))
(Defun _BuildAndEdit (key val lst)
  (if (setq f (assoc key lst))
    (subst (list key (append (cadr f) (list val))) f lst)
    (append lst (list (list key (list val))))
_$ MainList
(("list1" ("1" "2")) ("list2" ("11" "12")) ("list3" ("21" "22")) ("list4" ("31" "32")))
_$ (setq MainList (_BuildAndEdit "list2" "13"  MainList))
(("list1" ("1" "2")) ("list2" ("11" "12" "13")) ("list3" ("21" "22")) ("list4" ("31" "32")))
_$ (setq MainList (_BuildAndEdit "list5" "41"  MainList))
(("list1" ("1" "2")) ("list2" ("11" "12" "13")) ("list3" ("21" "22")) ("list4" ("31" "32")) ("list5" ("41")))
 HTH
Kent1Cooper
What are the bracketed numbers at the start of the lines?  Just for reference?  Are they variable names?  (You can use  [0]  as a variable name, but not just  0 .)
Your wording "a list of four values" suggests that the actual overall list is like this:
(("list1" ( "1"  "2" )) ("list2" ( "11"  "12" )) ("list3" ( "21"  "22" )) ("list4" ( "31"  "32" )))
in which case the bracketed numbers would be the index numbers of the "values" [i.e. sub-lists] in the overall list.  Is that right?  Is that overall list stored under a variable name?
Is [for example]  ("list1" ( "1"  "2" ))  really a list that includes a text string "list1" as its first item, along with a nested list ( "1"  "2" ) as its second item?  If the overall list above is not right, is this one stored in a variable called  [0]  ?  Your wording  ' I want to add the value "13" to "List2" '  makes it sound like maybe  list1  [without the quotation marks] is a variable name [not a text string] that contains the list  ( "1"  "2" )  as its only item.  Is that the situation?
Kent Cooper, AIA
nitin.rathod3CW9S
thanks a lot @pbejse . that was accurate solution I was looking for.
Moreover thanks for such a quick response. thanks again.
nitin.rathod3CW9S
[0], [1], [2],... represents index of the list inside list. actual list will look like below as you guessed already.
thanks for your response @Kent1Cooper
pbejse
Good for you, That's just one way of getting the result your looking for. its a Q&D code, you can develop it more by including conditions for sorting and some.
You are welcome @nitin.rathod3CW9S
