Can't set text size in command
davidlanesmith673
davidlanesmith673
I have this line in my AutoLISP code where pnt2 is a point, textH is the height, textA is the angle, and num is the output. In one drawing this works fine, but when I used this in another drawing, it wouldn't use textH to set the height, but rather would use a default height, use textH as the angle, and print out textA, ignoring num. How do I ensure that each argument is setting the right parameter.
(command "._text" pnt2 textH textA num)
pbejse
Check your current TEXTSTYLE <---  text height is set to a specific height the prompt for height is negated
davidlanesmith673
I set the height to zero and now it's working, thanks!!
Sea-Haven
A entmake will force height try it
(defun Text (pt hgt str)
 (entmakex (list (cons 0 "TEXT")
                 (cons 10  pt)
                 (cons 40 hgt)
                 (cons 1  str))))
