Alphabetically Sort List of Layers in a drawing
betsy.kirtland
betsy.kirtland
Hi all,
I have a lisp routine that retrieves a list of all the layers in the active drawing using the following code, stolen entirely from Afralisp (https://www.afralisp.net/visual-lisp/tutorials/visual-lisp-and-layers.php😞
(setq acadobject (vlax-get-Acad-Object))
(setq activedocument (vla-get-activedocument acadobject))
(setq LayerTable (vla-get-layers activedocument))
(vlax-for each LayerTable
    (setq LayerList (cons (vla-get-Name each) LayerList))
    );end vlax-for
The trouble is that the resulting list in a seeming random order.  The list is going to be used to populate a DCL popup_list, so I'd like the list to be in alphabetical order.
I tried the following, but as you see, I get an error:
_$ (vl-sort LayerList (function (lambda (s1 s2) (< (vl-symbol-name s1) (vl-symbol-name s2)))))
; error: bad argument type: symbolp "GE-TEXT-LABL"
I feel like there has to be an easy way to do this... or is it more complicated than I realize??  Any help would be greatly appreciated!
Kent1Cooper
If LayerList is a list of text strings, just:
(vl-sort LayerList '<)
EDIT:  The making of that list of Layer names can be simpler -- no need to get the Acad object and the active document, generate a table of Layers and then step through that to extract the names, etc.  As long as 'lay' is a localized variable so for purposes of the routine it will always start as nil:
(while (setq lay (tblnext "layer" (not lay)))
  (setq LayerList (cons (cdr (assoc 2 lay)) LayerList))
Kent Cooper, AIA
betsy.kirtland
Thank you @Kent1Cooper !  I also realized that acad_strlsort would also accomplish the alphabetical sorting without the need for an anonymous function.
