lisp to export /import the layers Properties Filter in autocad 2019
JM_THS_4Y
Message 1 of 19
JM_THS_4Y
Good afternoon everyone,
I'm asking if you can help me with a lisp that can export the layers Properties Filter I have in a drawing and then import them into any other drawing (Autocad 2019).
They are not Filter Properties (in group) they are individual.
Thank you all for your help.
Replies (18)
Message 2 of 19
dbroad
Your illustration doesn't show any filters. Without using lisp, start the layer command. Then choose the layer states button(or just use the layerstates command). Create a new layer state and then export it.  In any other drawing, import the layer state.
You can also just insert a drawing into any other drawing.  All the layers will be created. Then just delete the drawing and purge the additional stuff out.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 19
JM_THS_4Y
Thanks for the answer, but that's not what I need, it's exporting simple filters, not as groups or layer states.
Thanks anyway.
Message 4 of 19
pbejse
Thanks anyway.
Show us then what exactly do you need @JM_THS_4Y so there is no confusion
Message 5 of 19
JM_THS_4Y
what I need is a lisp that takes all the layer filters that any drawing has and exports these filters so that I can later import them into other drawings that don't already have those same filters created.
So in all drawings, whether new drawings or already in work, but at any time you can import the filters that were exported before and so it is possible to import this information for the drawings you want.
I don't know if I was clear, I'm sorry.
what I need is not to export the layer state, that doesn't solve me.
thank you very much
Message 6 of 19
pendean
Community Legend
Community Legend
Read this while you wait (signing up is totally free if you are not a member) https://forums.augi.com/showthread.php?173035-Importing-Layer-Filters-into-multiple-drawings
Message 7 of 19
JM_THS_4Y
thanks,
the solution from https://www.augi.com/forums/showthread.php?97438-Can-I-create-frequently-used-layer-filters-in-LISP&... with lisp LayerFilter.lsp works in part.
It only exports and imports one filter at a time, but it's always better than nothing.
Ideally, export all the filters, then import them all again, but that at least helps.
If however someone with more knowledge can help improve this lisp, to export all and then import all or with the possibility of selecting several that would be very good.
Thanks again for the help so far.
Message 8 of 19
ВeekeeCZ
Some verticals have these features built-in, C3D include. It's
LAYERLOADFILTERTREE
LAYEREXPORTFILTERTREE
Also, dotsoft had some free stuff that worked with layer filters. You can try it HERE
Message 9 of 19
pendean
Community Legend
Community Legend
While you wait... see "solution" offered by Autodesk for plain AutoCAD users https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Message 10 of 19
JM_THS_4Y
thank you, but this is not what i need.
Message 11 of 19
pbejse
Any chance you get post a sample drawing with filters already set up?
Message 12 of 19
JM_THS_4Y
Yes,
thanks
Message 13 of 19
ВeekeeCZ
Seems to me that it works flawlessly. Or are you aiming to do some self-learning exercise? 📖
Message 14 of 19
pbejse
Tested on AutoCAD 2017 | Export only with lft file option
Command: ImpAllFltr
Command: ExpAllFltr
HTH
Message 15 of 19
JM_THS_4Y
excellent,
thank you very much, that was it!
very grateful for the help.
5 stars
thank you very much
Message 16 of 19
S_S_SS
it's an excellent lisp
can you make it for "dwg" files sir ??
and thanks in advance
Message 17 of 19
raja_shahbazQN4N3
but it give option to export one by one is it possible to export all filter in one time
Message 18 of 19
jarreTRXLH
Is there a way to modify this LISP to export and import the complete Filter Tree structure?
So to include all subfilters that may be present in a property/group filter?
Message 19 of 19
john.demeyer
i know this is a old treath, but i also lokking if there is a way for the filter tree to export and iport.
Thx, greetings John
