[LISP] Writing a UNICODE character to a file - how?
iBlachu
iBlachu
I am trying to write a unicode character to a file so that it is visible when I open the file.
(setq f (open "c:/1.txt" "w"))
(write-line (read "\"\U+00A9\"") f)
(close f)
I try in different ways:
(write-line "\\U+00A9" f)
(write-line "\U+00A9" f)
But instead of getting an © in the file, I get \\U+00A9 all the time.
Anyone have any idea how to get 1 character defined by unicode in file?
vladimir_michl
You can use Unicode when LISPSYS is set to 1 (since release 2021).
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
ronjonp
Maybe this?
(setq f (open "c:\\1.txt" "w"))
(write-line (chr 169) f)
(close f)
Sea-Haven
Whilst (chr x) works you need to look also at what text style you have set if your reading the file for adding text.
Try setting Windings as current text style the text file will have a character that is not the windings character. It appears to be ignored by the  write function.
(defun c:test ( / f)
(setq f (open "D:\\acadtemp\\1.txt" "W"))
(write-line (chr 65) f)
(write-line (chr 68) f)
(write-line (chr 72) f)
(close f)
(setq f (open "D:\\acadtemp\\1.txt" "R"))
(while (setq str (read-line f))
(princ str)
(command "text" (getpoint "\npick point ") "" str)
(close f)
(princ)
(c:test)
If you go to Windows, Fonts, "Find a character" you can work out the (chr x)
