Join two separate texts
Oliver_C3D
Message 1 of 17
Oliver_C3D
Hi
I have a file whose texts are separated in decimal places. I want to merge them before and after decimal places with Position Z correct
Replies (16)
Message 2 of 17
hak_vz
This can be done in many ways and it's easy to do.
Let say,  we select all point (donuts....) representing a decimal point. Find red text and blue text near to point and join them together. Simple task but it requires that you post sample dwg (do this with every request to help us in creating code).
Miljenko Hatlak
Message 3 of 17
calderg1000
Regards @Oliver_C3D
Try this code. If it doesn't fit what you require. Please post an example Dwg.
(defun c:Jtext (/ s ltx i en tx ltx pins lay h ltf tt)
  (setq s (ssget '((0 . "text"))))
  (setq ltx ())
  (repeat (setq i (sslength s))
    (setq en  (entget (ssname s (setq i (1- i))))
          tx  (cdr (assoc 1 en))
          ltx (cons tx ltx)
  (setq pins (cdr (assoc 10 en))
        lay  (cdr (assoc 8 en))
        h    (cdr (assoc 40 en))
        ltf  (reverse ltx)
        tt   (strcat (nth 0 ltf) (nth 1 ltf) (nth 2 ltf))
  (setq pins (mapcar '+ pins (list 0. 0. (atof tt))))
  (entmake
    (list (cons 0 "text") (cons 8 lay) (cons 10 pins) (cons 40 h) (cons 1 tt))
  (vl-cmdf "erase" s "")
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 4 of 17
Sea-Haven
Really need a dwg, one software package I have used would make the decimal point the actual points X&Y&Z this is tricky to work backwards from as the font starts to impact. Even down to the characters used compare 111 to 222
Message 5 of 17
Kent1Cooper
Just to confirm what I think it looks like in the image [and which would also be answered by a sample drawing]:  Is the decimal point also a Text object?  Not something else, such as a Point, or a Block, or...?
Kent Cooper, AIA
Message 6 of 17
Oliver_C3D
Message 7 of 17
ВeekeeCZ
It would so nice if you actually think about what you're doing.
(vl-load-com)
(defun c:C3DJoinSepHeights ( / :strcat e i c d x)
  (defun :strcat (x d)
    (setq x (vl-string-trim " " x)
	  d (vl-string-subst ". 0" ".  " d)
	  d (vl-string-subst "." ". " d))
    (if (wcmatch d "*`%100")
      (setq x (itoa (1+ (atoi x)))
	    d ".00"))
    (strcat x d))
  (if (setq s (ssget '((0 . "TEXT"))))
      (setq e (ssname s (setq i (1- i)))
	    c (cdr (assoc 1 (entget e))))
      (if (wcmatch c "`.*")
	(setq d (cons (list e c (reverse (cdr (reverse (cdr (assoc 10 (entget e))))))) d))
	(setq x (cons (list e c (reverse (cdr (reverse (cdr (assoc 10 (entget e))))))) x)))))
  (foreach e d
    (and (setq m (car (vl-remove-if-not '(lambda (y) (< (abs (- (distance (last e) (last y)) 8.58)) 0.01)) x)))
	 (entmod (subst (cons 1 (:strcat (cadr m) (cadr e)))
			(assoc 1 (entget (car e)))
			(entget (car e))))
	 (entdel (car m))))
  (princ)
Message 8 of 17
pbejse
(defun c:Merger	(/ ss i e ent data)
  (if (setq ss (ssget "_:L" '((0 . "TEXT") (1 . ". %#*,. #*, #**"))))
    (repeat (setq i (sslength ss))
      (setq e	 (ssname ss (setq i (1- i)))
	    ent	 (entget e)
	    data (mapcar '(lambda (d) (cdr (assoc d ent))) '(1 10))
      (if (/= (setq zValue (last (cadr data))) 0.0)
	(entmod
	  (subst (cons 1
		       (strcat (rtos zValue 2 0)
			       (vl-string-left-trim ". %" (Car data))
		 (assoc 1 ent)
		 ent
	(vla-delete (vlax-ename->vla-object e))
  (princ)
HTH
Message 9 of 17
ВeekeeCZ
Since my remark still applies, it is probably worth noting the differences (not saying that mine is right and the other is wrong)
source - mine - pbe
 770 .  7 - 770.07 - 770.7
 769 . %100 - 770.00 - 769.100
Message 10 of 17
Oliver_C3D
@ВeekeeCZ  It would be better if the value was in position z after joining the text
Message 11 of 17
ВeekeeCZ
Not sure what that means. Both codes keep the original z value.
Edit: Now I see what you mean, probably...
Try this code - rewritten according to smart @pbejse 's algorithm.
(vl-load-com)
    (if (wcmatch d "`.#")
      (setq d (strcat d "0")))
	    d ".00"))
    (strcat x d))
      (cond ((wcmatch c "`.*")	(setq d (cons (list e c (cdr (assoc 10 (entget e)))) d)))
	    ((wcmatch c "*`.*"))
	    (T (entdel e)))))
  (foreach e d
    (and (setq z (last (last e)))
	 (entmod (subst (cons 1 (setq z (:strcat (rtos z 2 0) (cadr e))))
			(entget (car e))))
	 (entmod (subst (list 10 (car (last e)) (cadr (last e)) (atof z))
			(assoc 10 (entget (car e)))
			(entget (car e))))))
  (princ)
Message 12 of 17
john.uhden
@Oliver_C3D
I think someone where you work has a bad habit, especially if you don't plot in color.
But aren't the responders wonderful... to try to provide you a solution.  I could swear they spend more time helping than working, but that could be because they are independently wealthy and don't have to work.  🤑  I dunno.
John F. Uhden
Message 13 of 17
Oliver_C3D
thank you very much @ВeekeeCZ
There is only one problem if the number is 755.7, for example, it changes to 755.07, which is wrong. That's right, 755.70
Message 14 of 17
ВeekeeCZ
Ok, the last code was updated.
Message 15 of 17
calderg1000
Regards @Oliver_C3D
Since you already have a solution to do it by selecting several texts at the same time. Update my initial code to join the texts selecting two by two, consecutively.
In the case of texts that represent their elevation and it is possible that with this a TIN surface will be built, it surprises me that a fixed insertion point is not required.
(defun c:Jtext ( / s ltx i en tx ltx pins lay h tt)
  (while
  (setq ltx ())
          tx  (cdr (assoc 1 en)))
          (repeat 2
          (setq tx(vl-string-subst "" " " tx)))
          (setq ltx (cons tx ltx))
  (setq pins (mapcar '+ (cdr (assoc 10 en)) '(3.18 0 0))
        tt   (strcat (nth 0 ltx) (nth 1 ltx))
  (entmake
    (list (cons 0 "text") (cons 8 lay) (cons 10 pins) (cons 40 h) (cons 1 tt)(cons 73 0))
  (vl-cmdf "_erase" s "")
  (princ)
Carlos Calderon G
Message 16 of 17
Sea-Haven
Converting text to 2d points for making TIN's has that problem where is the true point, some point is insertion point, I know of the decimal point is correct point, this is hard to work out.
Message 17 of 17
john.uhden
@Sea-Haven
IMHO, it's a stupid idea to use just text to represent a survey point, unless maybe you are preparing an approximate topo survey of thousands of unblemished acres.  Certainly DCA->Softdesk->Land Desktop never provided for such an approach.
John F. Uhden
